Quick valve adjustment question
Old Sep 10, 2007 | 08:18 AM
Secret Chimp's Avatar
Default Quick valve adjustment question
I have no idea when the valves were last checked on my Accord, so I might as well do that job. What I'm wondering is if I need to remove the timing belt cover to be able to manually turn the crank to get to the individual cylinder TDC points. I've heard the timing belt cover is horrible to get loose, I just want to know what I'm getting into (if that's even necessary).
Old Sep 10, 2007 | 08:59 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Quick valve adjustment question (Secret Chimp)
you have to remove the upper timing cover to see the cam gear. It's only 2 bolts and it's off after you've removed the valve cover of course.
the lower timing cover is the one that is a pain and that doesn't come off to do a valve adjustment.
Old Sep 29, 2007 | 03:51 PM
SuShiBoiiii's Avatar
Default Re: Quick valve adjustment question (TouringAccord)
super thread revive but how often are you supposed to do it?
Old Sep 30, 2007 | 05:13 AM
Chiovnidca's Avatar
Default Re: Quick valve adjustment question (SuShiBoiiii)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuShiBoiiii &raquo;</TD></TR><TR><TD CLASS="quote">super thread revive but how often are you supposed to do it?</TD></TR></TABLE>
Depends on the year and model.
Old Sep 30, 2007 | 10:08 AM
Duane_in_Japan's Avatar
Default Re: Quick valve adjustment question (Chiovnidca)
I am sure there is a recommended interval but remember, the looser they are, the more your valve tips and rockers are getting beat up, back in the day, it was part of my yearly tune up. Manufactures report longer and longer intervals as a sales gimmick, the less maintenance you have to do, the cheaper it is to maintain your vehicle on a yearly basis, take care of your engine and it will take care of you.
Here in Japan, once every 4 years due to the cost of tune up parts, milage is low yearly anyways, all city driving.
Old Sep 30, 2007 | 02:00 PM
kidcool1977's Avatar
SHAME ON YOU REBECCA!
Community Builder
Default Re: Quick valve adjustment question (Duane_in_Japan)
i have a 94 lx, and i can hear my valves tick and tock, been putting it off for so long, anyways don't you have to remove the passenger motor mount in order to take off the side cover.
Old Sep 30, 2007 | 05:11 PM
Default Re: Quick valve adjustment question (kidcool1977)
Only the valve cover, you will need a new valve cover gasket, seal washers for under the nuts that secure the cover and the spark plug hole seals, and some parts cleaner.
Old Oct 1, 2007 | 04:52 AM
H-T Order of Merit
no, you do not need to remove the side motor mount to remove the side timing cover.
Old Oct 1, 2007 | 10:01 AM
Charri's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duane_in_Japan &raquo;</TD></TR><TR><TD CLASS="quote">I am sure there is a recommended interval but remember, the looser they are, the more your valve tips and rockers are getting beat up, back in the day, it was part of my yearly tune up. Manufactures report longer and longer intervals as a sales gimmick, the less maintenance you have to do, the cheaper it is to maintain your vehicle on a yearly basis, take care of your engine and it will take care of you.
Here in Japan, once every 4 years due to the cost of tune up parts, milage is low yearly anyways, all city driving.</TD></TR></TABLE>
94-97 regardless of trim/motor recommended every 15k or yearly
according to the haynes manual
Old Oct 1, 2007 | 05:04 PM
Default Re: Quick valve adjustment question (Mr Wonderfull)
If you do reuse the gasket, I would at least get 4 new spark plug hole seals, added insurance against oil leaking into the spark plug wells and damaging the wires.
Old Oct 2, 2007 | 03:27 AM
H-T Order of Merit
I'm not sure where the boosted and blowby come into play. many people without boosted engines have had issues with either the upper or lower spark plug tube seals, it seems like mostly the uppers though.
and as a general rule, I just replace the valve cover gasket when I remove the valve cover, unless I just replaced it recently. Just to be sure I wont have any leaking problems.
Old Oct 2, 2007 | 04:49 AM
Community Builder
i just ordered the VC kit from majestic honda, only 25 bucks. i'll be doing mine this weekend, hopefully my engine will quiet down, but anyway if i were to do this every 15k, i'd spend the 25 bucks just to be safe. just my thought
Old Oct 2, 2007 | 07:40 AM
Honda-Master's Avatar
no need to remove the upper timing belt cover,,,
http://www.hondaaccordforum.co...m.htm
hope this helps
rice h8r
Jul 15, 2011 09:32 PM
s2kkid
Jan 31, 2005 11:58 AM
Mark Finley
Sep 7, 2004 12:35 AM
kniob
May 4, 2004 01:34 PM
brcivic411
Dec 19, 2003 12:37 PM
