air fuel ratio
Old Jun 16, 2002 | 10:32 AM
Speedz's Avatar
Default air fuel ratio
besides the ECU what other ways can you tune your A/F ratio?
i've seen FPR and such, but dont have enough knowledge about the whole fuel system to know how to tune it.
i have some LS race cams i want to use.. 11.4mm lift (intake)
i have some b16a pistons to up my Compression ratio.
the head is ported/polished, with crower dual valve springs and titanium retainers, 3 angle valve job. shaved .030" ... also have AEM cam gears.
and performance ECU chip.
right now i'm running stock cams (93 integra RS) with all the other stuff cuz i run really rich with those Race cams.
i have an extra TB and IM that i'm getting bored and matched to 62mm.
i'm wanting to use the race cams, but until i can get it running right, i'm still using stock cams.
i realize they're gonna run lopey cuz they're kinda extreme, but running super rich.. well thats something that i dont want.
any comments/help?
thanks
Old Jun 16, 2002 | 12:02 PM
Project X's Avatar
Default Re: air fuel ratio (Speedz)
You will need to retune your ECU if you're running race cams. For temporary solution, you can use a S-AFC to lean out at 1000 rpm so that the car can idle.
Bored out the TB to 64mm and match it with a S2 or ITR IM.
Old Jun 16, 2002 | 02:59 PM
Speedz's Avatar
Default Re: air fuel ratio (Project X)
thanks, i dont know about going Skunk2 IM right now.. thats outta my budget for the time being, plus i'm not sure if i am gonna stay non vtec..
any other ideas? and suggestions?
DOHC 4 life
May 29, 2009 02:14 AM
motormike40
Dec 26, 2007 10:21 AM
Pony_Fed95
Oct 31, 2005 02:28 AM
FAST94GSR
Nov 11, 2001 03:32 PM
