need help.....tranny problem
well my transmission was not going into gear and was leaking so i took it off and found a hole in the side of it. then when openin the transmission up the final drive pinion shaft was broken. the shaft has 14 gear teeth and the gear has 64 i have no clue on if its a type r or a b16 final gear so if any one can help that would be great i will try to get some pics up.
coreysef
Transmission & Drivetrain
Apr 21, 2011 10:43 AM
