ARP head studs install. please help!!!
Old Sep 9, 2007 | 08:43 PM
eg64u's Avatar
Default ARP head studs install. please help!!!
OK, so this might sound dumb, but im thinking if you pull the cams and what not and timing belt as usual to do a arp install. and if you drain the coolant. is it possible to leave the head on and keep the same headgasket on also and retorquing it with the new arps and not having a problem? basically im asking is it possible to not pull the head to install the arp studs? I know once th head has been heat cyclned on the block it is on there pretty good, so thsi is why i ask.
cliffs: fresh itr motor with about 40k on it, want to keep stock headgasket but put arp studs for boost. is it ok to leave head on while doing arp install?
thanks in advance
Old Sep 9, 2007 | 11:15 PM
badboyr66's Avatar
Default Re: ARP head studs install. please help!!! (eg64u)
Guess you could. But why go that far and skip out on the HG? It is a good time to throw the cash up on quality piece. Cheap insurance.... but you have your reasons
Old Sep 10, 2007 | 12:24 PM
eg64u's Avatar
Default Re: ARP head studs install. please help!!! (badboyr66)
well, why waste a head gasket if its seated and you didnt blow one? thats the way i look at it. most likely i will pull it off, but if theres enough feedback on doing it with the head on already, i may just do that instead. thanks for the feedback, and yea i have a headgasket already. ill most likely change it and copper spray it just in case.
thanks
bump
Old Sep 10, 2007 | 01:19 PM
h22crxpwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg64u &raquo;</TD></TR><TR><TD CLASS="quote">OK, so this might sound dumb, but im thinking if you pull the cams and what not and timing belt as usual to do a arp install. and if you drain the coolant. is it possible to leave the head on and keep the same headgasket on also and retorquing it with the new arps and not having a problem? basically im asking is it possible to not pull the head to install the arp studs? I know once th head has been heat cyclned on the block it is on there pretty good, so thsi is why i ask.
thanks in advance </TD></TR></TABLE>
you have to loosen and remove the stock headbolts anyway which will loosen the head and gasket from the block, plus when you install the arp's you want to be sure that there is no water or anything in the hole and its pretty hard to do that with the head still on the block. just take the head off and install the arp's if you want to be cheap just reuse the headgasket. i wouldnt but i've done it and it worked. headgaskets are pretty cheap now from the aftermarket. i've found them for less than 30 bucks! and they work fine. but its up to you. if you don't mind possibly having to take the head off again then go for it and just reuse the gasket after you take the head off. for 30 bucks or so i'd rather just go buy a new one
Old Sep 11, 2007 | 08:15 AM
eg64u's Avatar
Default Re: ARP head studs install. please help!!! (h22crxpwr)
yea cool, thanks for the reply , im gonna replace it, seeing that i have the gasket here, and im gonna use some copper spray just for extra precaution.
thanks again
TomCurllyFry
Apr 16, 2013 09:25 AM
DelSol-B18
Sep 8, 2012 06:24 PM
big-cat
Sep 14, 2007 12:54 PM
boomersz
May 7, 2007 07:37 PM
caster troy si
Sep 15, 2005 11:41 AM
