USDM B18C1 TO JDM SWAP B18C WHAT DO TOU DO WITH CKS SENSOR?
Old Sep 9, 2007 | 06:15 PM
JAMN J's Avatar
Default USDM B18C1 TO JDM SWAP B18C WHAT DO YOU DO WITH CKF SENSOR?
I AM IN THE MIDDLE OF SWAPPING EVRYTHING OVER AND NOTICED THAT YOU CAN NOT MOUNT THE CKF SENSOR BECAUSE THE BLOCK IS DIFFERNET. IS THERE A EASY FIX , DO YOU HAVE TO MODIFY THE ECU CAN SOMEONE HELP? I KNOW THERE HAS TO BE SOMETHING CAN SOME HELP WHO HAS DONE THIS SWAP.
1999 ACURA INTEGRA GSR
B18C MOTOR W/P72 HEAD
Modified by JAMN J at 8:00 PM 9/9/2007
Modified by JAMN J at 8:32 PM 9/9/2007
Old Sep 11, 2007 | 03:56 PM
stumpyf4's Avatar
Default Re: USDM B18C1 TO JDM SWAP B18C WHAT DO YOU DO WITH CKF SENSOR? (JAMN J)
Here u go.
http://technet.ff-squad.com/ckftrick.htm
Or swap the OBD1 Oil Pump to a OBD2 Oil Pump.
gsr-t9303
Apr 22, 2011 10:23 PM
gsr-t9303
Mar 30, 2011 09:45 PM
reyrey2006
Sep 18, 2008 10:34 AM
98 gsr teggy
Apr 19, 2007 08:38 AM
tHeeeazy E
Mar 28, 2006 10:52 AM
