Torquing down crank pulley bolt
Old Sep 9, 2007 | 05:31 PM
PreludePhill's Avatar
Default Torquing down crank pulley bolt
Whats the best way to keep the crank from turing while torquing the crank bolts down?Leave the car in gear?
Old Sep 9, 2007 | 05:39 PM
117's Avatar
117
Use a crank pulley holding tool. If not, put the car in gear, but the engine will move quite a bit before you'll be able to get the bolt torqued.
Old Sep 9, 2007 | 06:04 PM
99_SH's Avatar
or the shove a screw driver in the flywheel peep hole to stop the crank from moving...
Old Sep 9, 2007 | 06:13 PM
Thanks guys
Old Sep 9, 2007 | 06:23 PM
mgags7's Avatar
Default Re: (99_SH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99_SH &raquo;</TD></TR><TR><TD CLASS="quote">or the shove a screw driver in the flywheel peep hole to stop the crank from moving...</TD></TR></TABLE>
Get the crank pulley tool. Its not very expensive.
Old Sep 9, 2007 | 10:52 PM
marks_lude's Avatar
Default Re: (mgags7)
put it in 5th and have someone stomp on the breaks.
worked every time for me, easy as pie
Old Sep 9, 2007 | 11:06 PM
JT's Avatar
JT
Default Re: (marks_lude)
That's the easiest way for manual tran. Otherwise, use the pulley tool.
alex14
13
Dec 10, 2010 09:28 AM
royalfelix
Sep 7, 2007 01:51 PM
fe519
May 13, 2005 07:19 AM
94si94cx
Oct 19, 2003 10:36 AM
wizzards581
Dec 8, 2002 06:06 PM
