ecu problem??
Old Sep 9, 2007 | 05:25 PM
v8 integra's Avatar
Default ecu problem??
ok so i have a jdm b16 p30....my friend at work said he has a chipped p28 and it will make my car run better cuz i have a few boltons and it will make my vtec kick in aroudn 5 instead of 6k.. so i tried it out and drove fine...i switched my p30 back in because i didnt have the amount he was asking for..after i put the p30 back in...my idle went lowwwwwwwwwww and my shifts were bad from the rpm dropping so quickly...i checked the code i got..code 14 iac..i searched but nothing related to this..thanks honda-tech!
also unplugged the negative from the battery for an hour
Modified by v8 integra at 7:19 PM 9/9/2007
Old Sep 10, 2007 | 05:54 AM
v8 integra's Avatar
Default Re: ecu problem?? (v8 integra)
plzzz i need thhis car running.....
Old Sep 10, 2007 | 06:17 AM
THC07's Avatar
try unhooking the ecu for a little longer. clean that iac alos.
let us know if you still have the code.
Old Sep 10, 2007 | 06:21 AM
crazyguy's Avatar
i had the same problem as u did. i have a jdm b16a swap with jdm p30 ecu and the car was running not very well..so i bought a chipped p28 ecu tuned to the spec and mod according to my car and it runs very smotth now. whats the price your friend is asking about his chipped p28 ecu? and trust me.jdm b16a swap will run smoother with chipped p28 ecu
Old Sep 10, 2007 | 08:39 AM
Relic1's Avatar
Default Re: ecu problem?? (crazyguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy &raquo;</TD></TR><TR><TD CLASS="quote">i had the same problem as u did. i have a jdm b16a swap with jdm p30 ecu and the car was running not very well..so i bought a chipped p28 ecu tuned to the spec and mod according to my car and it runs very smotth now. whats the price your friend is asking about his chipped p28 ecu? and trust me.jdm b16a swap will run smoother with chipped p28 ecu</TD></TR></TABLE>
a chip is only as good as what's programmed into it. A chipped ECU is only as good as the tune, and untuned chip is worth as much as a potato chip.
the P30 will run the B16 the way it was supposed to be run. As per honda. Anything deviating from there requires proper tuning.
OP: more than likely the chipped P28 (shouldn't be more than $125-150) had everything disabled so it didn't set a CEL, and ran open loop. Which will run the engine directly off the maps, which tend to be set richer for "more power". which can damage or foul sensors. (tends to reduce the life of the O2 and cat)
try unplugging and replugging in the ECU a few times (dirty connections)
try cleaning the IAT (I've never had any luck doing so but its worth a shot)
try a new IAT or a friends IAT.
Old Sep 10, 2007 | 03:27 PM
v8 integra's Avatar
believe it or not..ive cleaned out the throttle body...and ive gotten a new iat sensor a while back..i tried the 1 in my brothers integra......now the rpms jump up and down at idle
Old Sep 10, 2007 | 04:13 PM
THC07's Avatar
Default Re: (v8 integra)
http://www.ef-honda.com/ben/Badidle.php
Old Sep 11, 2007 | 12:38 PM
v8 integra's Avatar
thanks i hope this helP!
Old Sep 11, 2007 | 03:14 PM
v8 integra's Avatar
Ok so i cleaned out the iacv and it wasn't that dirty at all..i still have a crappy idle that bounces up and down...and i have cel14 which is iac...i cant find any vacume leaks..im going insane..i cant figure this out..anyone with any other suggestions??
Old Sep 11, 2007 | 03:42 PM
v8 integra's Avatar
also will air in my radiator(if i have any air in there) cause a idle problem to set off the iac cel 14???or is the cel 14 strictly just for the iac
Old Sep 11, 2007 | 07:50 PM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v8 integra &raquo;</TD></TR><TR><TD CLASS="quote">also will air in my radiator(if i have any air in there) cause a idle problem to set off the iac cel 14???or is the cel 14 strictly just for the iac</TD></TR></TABLE>
CEL14 is strictly for the IACV. you either have a wiring problem or faulty AICV.
either way it will cause bad idle for sure.
Old Sep 12, 2007 | 10:23 AM
v8 integra's Avatar
ive cleaned out the iac and i still have the cel 14 and the bad idle..wat should i do next?
Old Sep 12, 2007 | 12:16 PM
Relic1's Avatar
you can test the IACV, put 12V accross the two pins, this will pull the plunger to the side all the way.
when mine was bad, I looked into the holes and connected 12V and the plunger moved a little then sort of tilted sideways, and didn't open all the way.
as long as you don't hold the power on the AICV for more than several seconds it will be fine. (10 seconds would be fine and is more than enough to tell what's going on in there)
Old Sep 15, 2007 | 08:46 AM
v8 integra's Avatar
Default Re: (Relic1)
ok sooo i i tested the iacv..it was clicking...i even put a different iacv from a different civic into my car..and it seemed to bolt right on..i tighten the fitv screw..cleaned everything..i put my finger in the top hole of the throttle body and my idle seems perfect...im still so0o0 stumped
Old Sep 18, 2007 | 04:55 PM
e-tech's Avatar
Morning V8 ....
HAD the same problem like yours...
Did everything you did.
Finally borrowed a friend's ecu to pluck in...
Engine check light and idling became normal.
Have you tried another ECU?....
I'm trying to find the faulty component in the ecu... Anyone can help?
Old Sep 18, 2007 | 04:57 PM
v8 integra's Avatar
Default Re: (e-tech)
no i havent tried another ecu
Old Sep 18, 2007 | 05:05 PM
e-tech's Avatar
So why not try this first.
I suspect it is a common trouble for P30...
Any comments for others?
stackedhouse
May 17, 2012 05:37 PM
egbaby
Mar 7, 2008 11:23 AM
e-tech
Sep 28, 2007 10:36 AM
D15JDMARIO
Feb 23, 2007 03:38 PM
pinoyboy204
Jun 26, 2006 03:06 AM
