cam gears cover???
so i was changing all the seals and gaskets on the engine, im almost done, i hit a snag...it seems that after putting in the skunk2 cam gears the cover wont bolt on all the way...is there another cover that would fit...or can i just remove it? would that be safe? thanks for the input
You can cut out some round holes the size of the gears from the cover...that way you can access the bolts (which is probably what's hitting the cover anyway).
