Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
temp gauge stuck???
Old Sep 9, 2007 | 04:50 PM
chock289's Avatar
Default temp gauge stuck???
i posted earlier but i didnt get enough info....any help would be great.
2004 civic dx, 5sp, daily driver. 70,000 miles. 41 mpg.
temp gauge needle was pegged at H. thought i overheated but i did not.
replaced....thermostat, fan thermoswitch, and gauge sending unit.
disconnected battery for 10 mins. reconnected battery needle spun all the way around to other side of gauge!!!!! everytime i disconnect battery and reconnect needle ends up in a different position. ?????
when i turn key to on position the needle dances up and down, and each time i turn off and on . needle winds up in a different positon.
any thoughts???? thanks........also replaced front grounding strap.
how could i add another temp gauge, and not screw up the computer. do i splice into the wires coming off the temp sending unit??
Old Sep 10, 2007 | 08:40 AM
DsevenEm2's Avatar
ur asking two different things tho..
why would u buy ANOTHER temp gauge. FIX the one you have NOW.
Old Sep 10, 2007 | 09:48 PM
1llmatic's Avatar
New User
Default Re: (DsevenEm2)
sounds like an electrical problem with your gauge cluster.
Have you tried plugging in another cluster?
Dmascarenasp
Mar 14, 2016 11:15 AM
EGicon
Jan 6, 2013 01:30 AM
chock289
Sep 9, 2007 05:55 PM
Boofster
Dec 6, 2004 03:18 PM
