finally made out to track this year
Old Sep 9, 2007 | 02:09 PM
Allmotor B20's Avatar
Default finally made out to track this year
This was my first event this year and it was in montreal we made 4 consistant 11.30 passes but mph varied because I'm still learning the car and its a complete different set up then last year.
Like I said 4 passes, all 4 were 11.30-11.38 the slowest pass and mph went from 122- 135mph and hooking a 1.46 60foot but the high mph we hooked a 11.67 and 1.72 this track in the afternoon was ****. what do u guys think about the et and mph.
Modified by Allmotor B20 at 12:33 AM 9/10/2007
Old Sep 9, 2007 | 02:23 PM
.CUBISH.'s Avatar
Default Re: finally made out to track this year (Allmotor B20)
set up?
Old Sep 9, 2007 | 02:36 PM
JamaicanDave's Avatar
Default Re: finally made out to track this year (.CUBISH.)
very nice car... good luck with it
Old Sep 9, 2007 | 03:05 PM
We have a B20 bottom 85mm 15:1 compression 95mm stroke B16 head ported and polished with roller rockers and custom cams,dogbox transmission and a tilton clutch edelbrock Intake and header
Old Sep 9, 2007 | 03:07 PM
.CUBISH.'s Avatar
11.3@135mph? car should be in the low 10 sec range easy.. how much power?
Old Sep 9, 2007 | 03:20 PM
we made 236hp and 185 tourque with 8 intake valves slightly bent just found that out because we had to pull of the head do to a coolant problem this was on a dyno dynamics dyno
Old Sep 9, 2007 | 03:33 PM
Migrana's Avatar
look good
Old Sep 9, 2007 | 03:55 PM
Fred n J_v2.0's Avatar
236/185 and running 135? whats the car weigh? car looks good
Old Sep 9, 2007 | 05:11 PM
Bserious's Avatar
Default Re: finally made out to track this year (Fred n J_v2.0)
I assume with those times that was meant to say "122- 125mph". Still pretty good for the amount of power.
Old Sep 9, 2007 | 05:56 PM
Default Re: finally made out to track this year (Bserious)
Yea thats what we were expecting to see but when both of our last time slips showed 133mph and 135mph we were pretty shocked and the car weights 1675lbs
Old Sep 9, 2007 | 07:23 PM
skUnK2jdm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Migrana &raquo;</TD></TR><TR><TD CLASS="quote">look good </TD></TR></TABLE>
Old Sep 9, 2007 | 07:24 PM
SOHCboost's Avatar
look at the 3rd picture 11.3 @ 133
Old Sep 9, 2007 | 07:25 PM
tom@yoparts.com's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Allmotor B20 &raquo;</TD></TR><TR><TD CLASS="quote">Yea thats what we were expecting to see but when both of our last time slips showed 133mph and 135mph we were pretty shocked and the car weights 1675lbs</TD></TR></TABLE>
Gangsta
Old Sep 9, 2007 | 08:11 PM
f@sth@tch89's Avatar
Default Re: finally made out to track this year (tom@yoparts.com)
Car looks good...niiice times.
This gives me some numbers to shoot at. I have the same car with a similiar set up.
b20b block 84.5 mm w/ 13.5:1
s2s3 cams
s2 manifold
gsr head w/ alaniz head work
supertech valvetrain
stock tranny w/ act 6 puck ITR flywheel
once i can afford to get it back together i have some goodies i will be adding.
Looks good mane, keep us updated with more times.
Old Sep 9, 2007 | 08:19 PM
dreadcivicturbo's Avatar
your mph is crazy...nice car
Old Sep 9, 2007 | 10:26 PM
PSI2HI's Avatar
Former Vendor
1.46 60'
Old Sep 9, 2007 | 11:20 PM
hiya vtec's Avatar
Do you have any video of your car running in the 1/4th?
Old Sep 10, 2007 | 02:33 AM
AllMoToRB18c's Avatar
Default Re: finally made out to track this year (hiya vtec)
what size slick are you guys running?...looks like 23's...133-135mph is some tens...keep up the good work
Old Sep 10, 2007 | 05:19 AM
ELSpool's Avatar
It looks like Napierville, which is notorious for trapping a few mph high...
nice car!
Old Sep 10, 2007 | 07:01 AM
2fastGSR's Avatar
King of the One Liners
Default Re: (ELSpool)
mph is crazy for an 11.3 pass
nice setup and im LOVING the hood
Old Sep 10, 2007 | 07:06 PM
lilmex's Avatar
Default Re: (2fastGSR)
Anymore pixs?
Old Sep 10, 2007 | 07:35 PM
Default Re: finally made out to track this year (f@sth@tch89)
that motor that you're building should make at least 220hp on a good tune
Old Sep 10, 2007 | 07:38 PM
Default Re: (lilmex)
Thanks guys for the great feedback
heres some more pics and I'll keep u guys updated from a event this sunday
Old Sep 10, 2007 | 07:48 PM
1 2 NV's Avatar
im skeptical on the MPH part. you have a ton of TQ due to the stroke of the motor yet you trap 122 which is right on par for a low 11 second pass with 23XWHP. then your car weighs 1675. i would have assumed that with a 1.46 60 the car should have gone 10s easy at 122.
my car for example weighing 1800lbs or so with driver making 22X/150 ran 11.62 @116 with mid 1.6 60. driving on 23s
not sure what my car weighs now but at a crappy track where i have never gotten **** for traction i ran 11.51@118 with 24X/150 on a 1.68 or 9 60. i think the car still weighs around 1750w/driver. driving on 24s.
a guy in canada bought DTRs old car made 240 or so WHP and ran i think best of 10.7s with high 1.4 60s. car weighed 1625.
Old Sep 10, 2007 | 08:25 PM
Default Re: finally made out to track this year (1 2 NV)
yea a buddy a mine bought that car and yea he did that in norwalk last year
I know the mph sounds a little of but hitting it twice is a little screwed up plus were fixing the head know due to 8 slightly bent valves which we didnt know so we should make alot more then 230hp but will keep you guys updated this week
