Stud Bolt Size Please
Old Sep 9, 2007 | 02:07 PM
kittycatshake's Avatar
Default Stud Bolt Size Please
Im changing out my front and back wheel studs on my 97 accord because I just bought new wheels and had to use wheel spacers to make them fit. Can anyone tell me if the sizes of the bolts are the same on the front as they are the back? Can anyone also tell me the size os the stock stud bolts?
I've got 5 different answers and Im going crazy. Is it 12mm x 1.5 on the front and back, 12mm x 1.25 on the front and 12mm by 1.5 on the back? Most importantly, whats the stock length so I know what length to get since I have to get extended studs.
Thanks ahead of time.
Old Sep 10, 2007 | 05:18 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Stud Bolt Size Please (kittycatshake)
I'm fairly certain it's 12mm x 1.5
and I know for sure the front and rear studs are the same.
as for the length, I don't remember. I know I did check them before but I don't remember what it was. I think I still have mine from when I swapped them out for Acura RL studs (longer) so I can try to find them and measure them. I do know that the rear studs are slightly longer than the front studs because the front studs only pass through the hub while the rear studs have to pass through both the hub and rotor.
Old Sep 14, 2007 | 07:39 PM
does anyone know the stock length for the front and back? Im thinking one of these will work... http://www.coximport.com/store...-0830
Old Sep 14, 2007 | 07:52 PM
oem_certified_accord's Avatar
Default Re: (kittycatshake)
i doubt those are real skunk2 studs...RL studs, really TA? .. interesting.
Old Sep 15, 2007 | 05:43 PM
H-T Order of Merit
sorry, I cant check the stock length yet. I'm moving, just closed on my first house, so a lot of my stuff has already been boxed up for the move. Part of whats been boxed up is all my car parts so I wont be able to check that for a while, sorry.
Old Sep 15, 2007 | 05:45 PM
H-T Order of Merit
Default Re: (oem_certified_accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oem_certified_accord &raquo;</TD></TR><TR><TD CLASS="quote">RL studs, really TA? .. interesting.</TD></TR></TABLE>
yep, RL studs.
When I was looking into doing this I found a thread in the Civic forum I think where someone had used some RL studs. So I went to Acura and measured one and it was just what I was looking for. I'll see if I can find that thread. But RL studs did fit and worked just fine on my 95 EX.
EKhatch
Welding / Fabrication
18
Dec 20, 2012 04:17 AM
GSRCRXsi
Oct 14, 2005 03:51 PM
743power
18
Dec 28, 2002 06:09 PM
pmachan
Mar 21, 2002 03:53 PM
