help with tire size?
Old Sep 9, 2007 | 12:41 PM
mikeaitken's Avatar
Default help with tire size?
Right now im rockin 17' motegi ff7s wheels with 205/40r/ 17 80w. i want bigger tires to fill up my wheel well a little bit, cause i still wanna lower it but nothing too low pro.
any suggestions. im not good with tire **** at all. haha. im not sure what they are as far as 17 x what? i know thats the tires i have on em now tho. i just want sumtin bigger in height/sidewall
Old Sep 9, 2007 | 01:29 PM
britishdude's Avatar
Default Re: help with tire size? (mikeaitken)
Have a experiment with this tire size calculator, you put your existing sizes on the left and your intended bigger tyres on the right. It will also tell you how much your speedometer accuracy is affected, the best change is to alter the tire size so your speedo still remains as unaffected as possible.
http://www.miata.net/garage/tirecalcold.html
Old Sep 10, 2007 | 06:15 AM
Silver Surfer's Avatar
205/40/17 is a civic size.......it shouldn't be on your prelude to begin with
use that link in put in the stock size and play around until you find the right sizes
205/50/16
225/45/16
225/40/17
205/45/17
etc
Old Sep 10, 2007 | 07:59 AM
slysi92's Avatar
i had 205/40/17's when i got my wheels ut now am running 215/40/17 with h&r springs,they are a lil taller and wider, look lot better. i can post a pic later if you would like.
Old Sep 10, 2007 | 06:40 PM
mikeaitken's Avatar
Default Re: help with tire size? (slysi92)
yeah if you wouldn't mind, id appreciate it alot. thanks.
Old Sep 11, 2007 | 01:41 PM
slysi92's Avatar
these are 215/40/17 toyo proxes 4's, with H&R springs.
batto24GSR
Mar 20, 2013 10:33 AM
yaryar
Jan 10, 2008 07:11 AM
mikeaitken
Sep 13, 2007 08:02 PM
HuskerHybrid
Aug 26, 2005 06:58 PM
1NasteeEp
Apr 10, 2004 08:13 AM
