compression test and timing question.. need help please!
so i purchased a jdm h23 and dropped it in the car, before starting up, we did a compression test,
cyl 4 - 170
cyl 3 - 220
cyl 2 - 70
cyl 1 - 90
before installing the engine all i did was change the timing belt... the cams were at TDC and the crack procket key was at TDC also... what else could this problem be?
if the exhaust cam sprocket is off by one tooth could that be the problem?
cyl 4 - 170
cyl 3 - 220
cyl 2 - 70
cyl 1 - 90
ca-rs
May 9, 2008 12:53 PM
2wheelhunter
Sep 9, 2007 05:54 PM
