Just turned over 195000 miles on my rex
Old Sep 9, 2007 | 11:17 AM
thegooddoctorceretti's Avatar
Default Just turned over 195000 miles on my rex
i have about 1400 dollars to spend on a new engine, what should i get. sohc d16, and who sells online
Old Sep 9, 2007 | 11:24 AM
SIred91's Avatar
Rainman
Default Re: Just turned over 195000 miles on my rex (thegooddoctorceretti)
Old Sep 9, 2007 | 12:15 PM
rhd_ef8's Avatar
Default Re: Just turned over 195000 miles on my rex (SIred91)
before this gets locked, i'll try and help hmotorsonline.com, if you use google and search honda motor or honda engine it will prob return a FEW other places, gl
Old Sep 9, 2007 | 02:27 PM
EFM_ookie's Avatar
Default Re: Just turned over 195000 miles on my rex (rhd_ef8)
yehaaaaaaaaaaa
Old Sep 9, 2007 | 02:37 PM
IP RACING's Avatar
Default Re: Just turned over 195000 miles on my rex (EFM_ookie)
hmotors sohc zc. cant beat it. 400 dolllars for a new motor. keep your tranny, install a new clutch. cold air,header, exhaust. that will make you pretty happy. made me pretty happy compared to my old dx motor
Old Sep 9, 2007 | 03:00 PM
crazykamper's Avatar
i may have missed it, but why do you need a motor?
Old Sep 9, 2007 | 03:13 PM
stocker2shocker91's Avatar
I requested a short story for a title.
Default Re: (crazykamper)
just turned 209,000 on the da......and? haha plenty of life left
another buddy in town has a turbo one with 232,000
another guy i know has one with 250,000 on it and still pulls hard
**** son your engine is still young
Old Sep 11, 2007 | 08:42 AM
i have known about hmotors for awhile, i just dont recall seeing anysohc engines on there, thanks for the help i will look at it right now.
Old Sep 11, 2007 | 09:27 AM
rice a roni's Avatar
i got 265k who gives a ****.
Old Sep 11, 2007 | 09:53 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazykamper &raquo;</TD></TR><TR><TD CLASS="quote">i may have missed it, but why do you need a motor?</TD></TR></TABLE>
x4
What's wrong with it? I kept my stock D16A6 until ~250K with no problems.
Old Sep 11, 2007 | 09:55 AM
89efDUSTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazykamper &raquo;</TD></TR><TR><TD CLASS="quote">i may have missed it, but why do you need a motor?</TD></TR></TABLE> amen to that...
That mileage is still minute compared to others...and why buy a motor online. Why not go on the marketplace and save like 80%. Damn this thread is full of fail.
Old Sep 11, 2007 | 09:58 AM
BiG Chris's Avatar
you dont need a motor my last crx before i sold it had 260xxx with 8lbs of boost daily and always ran hard!
Old Sep 11, 2007 | 10:15 AM
hondacrx2's Avatar
i have 267,000 miles on a automatic. i have never rebiult any of it. and it still runs fine. i just keep oil in it. don't laugh at that car thou.i have one a ls swap and another with a b16 swap. i have a b18b1 engine for sale if u want it.
Old Sep 11, 2007 | 10:26 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: Just turned over 195000 miles on my rex (hondacrx2)
My care meter says, this is boring.
Old Sep 11, 2007 | 01:02 PM
i just got a lil scared about the big 200000, and i have a tendency to drive hard. but this page has helped alot. thanks everyone even the *********(i guess sometimes you gotta be cruel to be kind) should i replace any internals or something of the such
Old Sep 11, 2007 | 01:27 PM
89efDUSTY's Avatar
do the normal observations and check what needs to replaced @ a high mile marker. I.E. air/fuel filter, timing belt, water pump, seals, gaskets...seriously come on OP we don't know the condition your car is in. All I can honestly reccommend is checking everything and if it is damaged/leaking/wearing/rubbing/grinding/screaming/crying/glowing/falling off etc, keep it in mind of replacing. For a motor that can run for hours on just water for oil, I don't think you need to worry about internals unless there are obvious signs.
Old Sep 11, 2007 | 01:36 PM
exhaust has a big *** hole in it, just replaced passenger side cv shaft, did tune up, coolant drain and refill oil change, currently its at the shop. it started bogging down about ten minutes into driving it, i hit the gas it goes slower. dont know what it is. all electronics work. interior is perfect few silver dollar sized rust spots on exterior. needs suspension all the way around. switching to power slot rotors and ebc pads as soon as they get ups'd to me. Not a bad car for 1300.00. for those ten minutes it drives normal it rips. cruise works but the threaded nut broke behind the plastic so i gotta find a way to fix that
Old Sep 11, 2007 | 01:40 PM
SIred91's Avatar
Rainman
Sounds like a TPS sensor going bad, or a coil problem......
Old Sep 11, 2007 | 03:31 PM
roger93si's Avatar
Dont worry man your car is gonna last forever if u take care of it!
my old crx had 295xxx miles on it. ran hard evryday from work and bak.. with no problems.
my 94' dc right now has 195xxx miles, burns oil but still strong and going.
im not worried! , its a honda
Old Sep 11, 2007 | 04:36 PM
JJ's civic's Avatar
Default Re: Just turned over 195000 miles on my rex (roger93si)
i have 340000 on mine
Old Sep 11, 2007 | 06:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondacrx2 &raquo;</TD></TR><TR><TD CLASS="quote">i have 267,000 miles on a automatic. i have never rebiult any of it. and it still runs fine. i just keep oil in it. don't laugh at that car thou.i have one a ls swap and another with a b16 swap. i have a b18b1 engine for sale if u want it.</TD></TR></TABLE>
how much?
pm me
wow i did not know there were so many high mileage hondas around. not bad
ekblackcoupe
30
Feb 2, 2009 01:13 PM
sh3d3vilinme
Oct 1, 2008 10:55 AM
b16gurl
11
Apr 19, 2006 02:43 PM
pdcivic
Jun 14, 2005 11:35 AM
PnutNZ
May 13, 2004 01:26 PM
