Help with 2nd Oxygen sensor.
Long story short, For a motor swap of a Y8 into a 97 LX, i also swapped a y8 harness, only thing is the 2nd O2 sensor plug (on the harness) was apparently cut off. Now im aware it must be wired manually, but my problem is that after searching Honda's Parts' blueprints (Hondapartsunlimited.com) i still have not been able to find where on the wiring harness the 2nd 02 should be plugged into.
My question is: Where can i find a diagram of some sort of the 1996-1998 Civic EX wiring harness, more specifically to try and locate where the 2nd 02 sensor should be plugged into. As mentioned before, it was cut off due to impatient removal from the previous owner (car wreck) , the wires are still present somewhere, im just not sure of where exactly on the harness they should stem from. Rather than cut into my harness to try and find them (or even pin them out on the ecu) i was hoping someone could shed some light on the subject.
My JDM EJ8
17
Dec 19, 2008 06:08 PM
B96v6
Dec 16, 2005 06:34 AM
