What is the flow rate of coolant?
Old Sep 9, 2007 | 10:30 AM
ilandhopr's Avatar
Default What is the flow rate of coolant?
Does anyone know the approx. flow rate of coolant, car warmed up at idle?
I'm working on an engineering design project to use the hot coolant in a heat exchanger to heat water for a camping shower.
thanks.
Old Sep 9, 2007 | 03:19 PM
hondakevin21's Avatar
Default Re: What is the flow rate of coolant? (ilandhopr)
That depends on the size and design of the rotors on the water pump and the idle speed of the engine, as well as the temperature of the coolant.
Old Sep 9, 2007 | 06:41 PM
ilandhopr's Avatar
Default Re: What is the flow rate of coolant? (hondakevin21)
Yes, if you assumed a steady state, (i.e. constant idle speed, constant temperature of coolant after being warmed up ~180 deg F) would 5 GPM be a close approximation?
Old Sep 10, 2007 | 04:01 PM
I'd think thats pretty close.
Old Sep 10, 2007 | 05:02 PM
BigMoose's Avatar
Think about the efficiency of the otto cycle and the number of BTU's heading into the cooling system. That may help your calc's a bit also.
natebaur
Dec 27, 2009 07:22 PM
SpEeDyX
Jul 5, 2009 10:59 AM
blue89hatch
Aug 12, 2008 07:57 AM
IntegraG2
34
May 16, 2007 07:01 PM
Oracle17
Oct 13, 2003 09:20 AM
