need instrument panel help - 99 accord ex sedan
i want to replace all the "greenish" bulbs inside the car.
the last thing i cant figure out how to take apart is the instrument panel
can someone show me where there is a tutorial?
or maybe give me a little tutorial? prefered with pics since im not THAT car savvy
ive taken apart pretty much everything else already.
is this a big job? how long could this take?
thanks
thanks
thank you so much for the link
but i am stuck
the instructions say...
First remove the 2 screws on the under side of the top of the trim piece and pull the trim piece off.
"It is held in with 2 clips on the bottom corners" <-------
can anyone show me a picture of that?
i tried to pull it out with quite a bit of force but the edges are stuck strong.
could there be screws there?
is there a trick to doing this?
but i am stuck
It means, look at the bottom of the TOP trip bezel. There are two screws there. The bottom is held in with clips. You just pull it straight out towards you. The most effective technique i've found is to put my four fingers of from each hand, flat on the bottom of the trim piece, and using the friction, pull it straight out.
Harley Dyna2001
12
May 16, 2019 04:15 AM
