Removing wiper cowl?
Help!
Being from California and not understanding what cold and snow will do to a car, I turned on the wipers to remove the snow that fell on the windshield overnight while visiting Minnesota last winter. The wiper transmission linkage incurred damage and now they slap into the cowling when turned on. I want to replace the wiper linkage DIY but I can't figure out how to remove the plastic cowling to gain access. I purchased a Chilton repair manual at the local part store but the instructions there are too vague. I would appreciate any help. I have removed the four plastic snap plugs along the front side so far.
I have an 2006 Accord EX.
Thanks, Abel...
Thanks, Abel...
Re: Removing wiper cowl?
See links:
http://www.justanswer.com/honda/37os...da-accord.html
The following service bulletin was for 2003 Accord wiper recall; but, it has some applicable instructions.
http://www.driveaccord.net/forums/at...9&d=1218734416
Thanks for the information. It appears that the cowl for a 2003 is different than a 2006. I believe the retaining clips on the 06 are hidden on the underside of the cowl out of eyesight. After I removed the front retaining plugs (all that is visible) I tugged on the cowling pretty hard but it wouldn't budge. It seems to be held at the windshield edge of the cowl. Any ideas?
The instructions and the cowls for a 2003 and 2006 are the same. There are 6 clips (1 of the 6 holds both the left and right sides) that need to be removed to get the left side (driver's side) cowl off, you stated only 4 were removed.
That link picture is small and not clearly detailed, that is why you can't see them. There are 14 clips that need to be removed to completely remove both side cowl.
I believe its got a bunch of plastic clips that hold it on, which you will need to pry up to get out. Some of them may be hidden by caps.
Thanks I'll give it a try. I am just apprehensive of breaking the cowl and having the extra expense to buy a replacement. I'll post how it went.
Okay, found a picture on ebay. I added some arrows and notes. This is a view from the underside of the cowl.
You probably removed the 4 front clips from the top. The other 10 clips are under the cowl.
I've been so busy working on Xmas shopping I have to put this project off until Dec. 26th., unless I get some great new toy. Ha.
Merry Christmas to all and thanks "tech8".
bass04
03-23-2016 02:51 PM
bakkouz
10-02-2015 11:27 AM
iHARTmyHONDA
Lighting
11-16-2008 11:10 AM
