Is anybody using this water cool kit...gt35r
i want to pick this up....but i don't know if it will fit on my gt35r.....thanks
http://cgi.ebay.com/ebaymotors...ZWD1V
after looking at the pic...it looks like maybe, it can be turned a lil...to clear the cold side...thanks for the reply....anyone else???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@nnY »</TD></TR><TR><TD CLASS="quote">
precision banjo kit with a - 6 welded to it works great. atp turbo also has some good stuff</TD></TR></TABLE>
yea i seen your post about coolant going into your turbo...and i noticed you used that kit.....what did you use to weld the -an fittings...i just have access to a mig welder....
the precision kit just comes with aluminum banjo fittings with long pipes that they want you to slip a tube over and put a hose clamp. I cut the pipes to size and had a buddy tig weld the fittings onto the pipe ends the -6 wled on steel fittings work perfect and a welding shop wont charge much its a 5 min job
GreenBean
Feb 11, 2004 07:47 PM
