Blowd Head gasket 2 liter turbo
Old Sep 8, 2007 | 11:28 PM
Junior_7's Avatar
Default Blowd Head gasket 2 liter turbo
Hey.
I hope you can give some advice.
I bougth JG Engine dynamic engine. I assemble block and head, I used oem GE overborred 84mm head gasket, arp head studs, I torque 65 torqeu with arp molly.
We out together everthing.
We drove at 5 psi, about 100km. I pull it too 6000 rpm, I did it some times.
It started too leak on the 3 cylinder, the hole road was full off white smoke.
I have good A/F about 12-12.5 and only 5 psi sleeved b18c jdm engine.
managment system is crome.
some idea??
Old Sep 9, 2007 | 05:53 AM
Junior_7's Avatar
Default Re: Blowd Head gasket 2 liter turbo (Junior_7)
some ide???
Old Sep 9, 2007 | 06:24 AM
narfdanarf's Avatar
Jg sleeved blocks have been known to never be right. I personally know 2 people who have had sleeves that were messed up and wouldn't seal. Good luck getting them to fix it too.
Old Sep 9, 2007 | 06:26 AM
WalkerGSR1's Avatar
arp head studs are supposed to be torqued to 75 ft/lbs
Old Sep 9, 2007 | 07:52 AM
Junior_7's Avatar
Default Re: (WalkerGSR1)
with arp molly??
Old Sep 9, 2007 | 10:05 AM
Urugly's Avatar
what head gasket are you using? Cometic??
oops editing cause I just reread your post....GE...
Old Sep 9, 2007 | 10:17 AM
SwappedTURBOegg's Avatar
i tq mine to 80 with molly lube lol
Old Sep 9, 2007 | 10:20 AM
WalkerGSR1's Avatar
Yea with the moly it says on the paper in the box with the head studs.
Old Sep 9, 2007 | 05:19 PM
blackeg's Avatar
75 psi with the studs. i think i did the oem specs with an additional step to 75. (27,61,75??? i kinda forgot lol). yeah i stripped a headstud nut on the last step. the stud is fine.
anyway ive had similar problems but to a less extent with aebs sleeves. i had the **** decked out of the block and it fixed it. also new oe gasket helped as well with a brand new set of headstuds
Old Sep 9, 2007 | 07:59 PM
Junior_7's Avatar
Default Re: (blackeg)
It is a lot of work too deck the block.
I will try with a new gasket and 75 psi.
Vtec04
Engine Machining & Assembly
11
Oct 31, 2017 09:26 AM
Prelude900
May 10, 2015 02:47 PM
NIKADEM0
Nov 16, 2014 09:39 AM
b17 rolla
Jan 12, 2009 09:01 PM
austincrx
Sep 7, 2006 09:49 AM
