Gap in between hood and grill,help greatly appriciated
Old Sep 8, 2007 | 09:10 PM
Mikes2000civicsi's Avatar
Default Gap in between hood and grill,help greatly appriciated
hey guys..i was just wondering...i got a cf hood.was supposed to be password jdm.put it on my car.looks beautiful,but the only problem is that theres a finger gap in between the hood and the grill.i was wondering if theres any way to adjust it or anyhting,thanks
Old Sep 8, 2007 | 11:15 PM
Murk 'EM's Avatar
Default Re: Gap in between hood and grill,help greatly appriciated (Mikes2000civicsi)
no.... how would you adjust it? you cant just make a hood longer
Old Sep 9, 2007 | 05:30 AM
Default Re: Gap in between hood and grill,help greatly appriciated (95_acc0rd)
no not make it longer...to go down more nor forward
Old Sep 9, 2007 | 05:46 AM
jfruauff's Avatar
You can lower it a bit buy adjusting the rubber on the sides ( they twist up & down) and moving the hinge but youll end up with it not lining up even with fenders.
Old Sep 9, 2007 | 06:22 AM
instrument's Avatar
there's a small amount of movement possible with the four bolts that hold it to the hinge, do you have them as far forward as possible?
Old Sep 9, 2007 | 10:20 AM
Default Re: (instrument)
yea 1 sides more down then the other..ill go try it
Old Sep 9, 2007 | 10:27 AM
MR Rodgers's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95_acc0rd &raquo;</TD></TR><TR><TD CLASS="quote">no.... how would you adjust it? you cant just make a hood longer</TD></TR></TABLE>
Useless post
Old Sep 9, 2007 | 10:58 AM
97Ej6mike's Avatar
Default Re: Gap in between hood and grill,help greatly appriciated (str8linek)
Arent there those rubber adjuster things above both headlights, i dont know their exact name, but you can adjust them in or out to fix fitment. Not sure how much that will help your situation, worth a shot tho.
Old Sep 9, 2007 | 11:13 AM
Default Re: Gap in between hood and grill,help greatly appriciated (97Ej6mike)
ty guys...yea yes the left side i had to adjust down...still a gap but you know oem fitment hood thanks
Old Sep 9, 2007 | 11:20 AM
gsxr1k05's Avatar
correct me if i am wrong, but i believe that the rubber things are called bump-stops
Old Sep 9, 2007 | 11:32 AM
Ron454321's Avatar
Bump stops are usually referred to for your shocks.
Old Sep 9, 2007 | 11:49 AM
ke98248's Avatar
Default Re: (Ron454321)
Yeah, definately for the shocks.
wrestler72
Sep 10, 2007 06:52 PM
dadeboy1
Paint and Body
Aug 19, 2007 03:14 PM
Zaakro
10
Aug 4, 2006 12:56 PM
trustbuddy
Nov 18, 2005 03:27 PM
i HAVEtheADVANtage
May 13, 2003 07:04 PM
