Exhaust question
Old Sep 8, 2007 | 09:08 PM
99fbpem1's Avatar
Default Exhaust question
So I bought a used RSR exmag exhaust for my EM1, the guy didn't tell me he had cut out the cat on his car and extended the pipe, so there is no cat, just a resonator and the muffler. Car sounds good, but now I have an exhaust leak somewhere (that's what I think it is anywas, rattling sound, feels like something is hitting the underside of my car).
The resonator hangs kind of low under the car, I'm thinking I might have to lose the resonator. How much louder will the exhaust be if I take off the resonator? I guess I could always buy a high flow cat if cutting out the resonator is too loud. What are your guys thoughts?
Thanks
Old Sep 8, 2007 | 09:56 PM
RCautoworks's Avatar
Default Re: Exhaust question (95civicdx)
The resonator gives you that deep sound, don't cut it out.
Old Sep 8, 2007 | 10:04 PM
97Ej6mike's Avatar
Default Re: Exhaust question (RCautoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks &raquo;</TD></TR><TR><TD CLASS="quote">The resonator gives you that deep sound, don't cut it out. </TD></TR></TABLE>
X2, that would be a most unwise decision.
Old Sep 8, 2007 | 11:02 PM
99fbpem1's Avatar
Default Re: Exhaust question (97Ej6mike)
okay, well, i guess they will just have to tuck it up there, because it's about 2 inches off the ground if that
Old Sep 10, 2007 | 09:19 PM
99fbpem1's Avatar
another problem...
... The shop didn't put my o2 sensor in my piping. So I'm throwing a CEL. I'm going back tomorrow, if they just simply put it back in the piping will i throw a cel still, because my cat is gone, someone told me I needed a defowler plug.
Old Sep 10, 2007 | 10:23 PM
bballchris24's Avatar
yes, it will throw a check engine light if you just connect the o2 censor to a pipe. so just get a cat so you dont have the cel and so people dont have to smell your exhuast.
Old Sep 10, 2007 | 10:57 PM
99fbpem1's Avatar
Default Re: Exhaust question (bballchris24)
Besides getting a cat there is no way around this?
Old Sep 11, 2007 | 06:21 AM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civicdx &raquo;</TD></TR><TR><TD CLASS="quote">Besides getting a cat there is no way around this?</TD></TR></TABLE>
Not really, depending on where you are from, not having a cat can get you in loads of trouble. In NJ here, they do roadside inspections in certain areas during the summer months.
Old Sep 11, 2007 | 09:12 AM
99fbpem1's Avatar
do defowler plugs even exist? Wouldn't people with test pipes throw cel's also?
Old Sep 11, 2007 | 01:09 PM
99fbpem1's Avatar
I was going to get a cat, but my car is at the shop right now, and I don't have time to get them one yet. so there is no way to fix this. If not i'm buying a magnaflow flow through cat tonight
Old Sep 11, 2007 | 02:55 PM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civicdx &raquo;</TD></TR><TR><TD CLASS="quote">do defowler plugs even exist? Wouldn't people with test pipes throw cel's also?</TD></TR></TABLE>
Blox makes a gapper insert to pull the 02 away from the exhaust flow.
you can find them on http://www.inlinefour.com, under the exhaust section
It will eliminate the check engine light by fooling the 2nd oxygen sensor into reading less emissions, but by no means will this get you thru any inspection.
Mishako129
Jun 18, 2013 11:31 AM
slazman999
Mar 14, 2010 03:21 PM
Celica Freak
Oct 3, 2006 06:39 AM
kay_animation
Feb 8, 2003 04:25 PM
00 Si
Nov 21, 2001 09:05 AM
