Master clutch cylinder removal
do you guys has easy way on how to remove the master clutch cylinder, I have a civic manual which i downloaded from other site but it didn't specify the step by step removal.
Any help will be appreciated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jivi »</TD></TR><TR><TD CLASS="quote">matt do i have to remove the driver side wheel?</TD></TR></TABLE>
I didn't need to.
I didn't need to.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jivi »</TD></TR><TR><TD CLASS="quote">mate can you get a snaps on how they gonna do it? thanks.</TD></TR></TABLE>
I'll get them for you tomorrow.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jivi »</TD></TR><TR><TD CLASS="quote">thanks matt.</TD></TR></TABLE>
It's pouring rain outside.
I'll see if I can borrow the garage for a minute.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 »</TD></TR><TR><TD CLASS="quote">
Mine's free.
</TD></TR></TABLE>Mine's free.
Alright, here's what I got for a picture. The highlighted 3 parts are what keep your Clutch Master Cylinder attached internally.
I removed the Pin first, then the two nuts, and it slid right out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jivi »</TD></TR><TR><TD CLASS="quote">thank you very much matt.
another question, the bleeding process
.</TD></TR></TABLE>
I needed 2 people for this. One person sat in the driver's seat, pressing the pedal down/up, while I used my finger to control the the pressure on the line.
Basically, I loosened up the bleeder valve on the slave cylinder, then put my finger on the bleed hole. I had the person inside depress the clutch pedal all the way down, and hold the pedal down as far as they could. Then, I released pressure on my finger slightly, to release the air. I then reapplied my finger, and had the driver release the clutch, allowing no air to seep into the line. I repeated this process until my finger was being forced off of the slave cylinder bleed valve, by the fluid pressure. (This gets messy)
.</TD></TR></TABLE>I needed 2 people for this. One person sat in the driver's seat, pressing the pedal down/up, while I used my finger to control the the pressure on the line.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by da1lydr1ver »</TD></TR><TR><TD CLASS="quote">is the bleeder valve for the clutch located in front of the engine, next to/on the transmission?
i've been trying to find out where the bleeder valve is for some time.
Thanks!</TD></TR></TABLE>
On the nose-end of the transmission, there is a slave cylinder. The bleed valve is on it.
Group Image #7 (Bleeding valve is parts 1 & 2):
MoogieBoogie
17
Aug 12, 2013 11:53 AM
LSEGHATCH
Jun 11, 2006 11:04 AM
