My 2.0L build - Suggestion on TB
See https://honda-tech.com/zerothread/1922534
I am wondering if I made a slight mistake on the bored ITR throttle body that I used in this engine (64mm). I am re-thinking this and pondering the idea of getting something like a 68mm or maybe even a 70mm and port matching the intake manifold and doing a re-tune. I have researched many threads and wanted to get some more input from anyone that has a similiar build. If i keep this engine in the 6800-8200 RPM range would this benefit or take away useable power?
Thanks,
Mike
Thanks,
Mike
Going from 64mm to 68mm will not net you huge gains, but you will get a couple. You might also notice slightly improved throttle response.
crippledeg
Jan 29, 2004 04:41 PM
B18Redline
Jun 3, 2002 01:12 PM
