93 del sol s SWAP
Old Sep 8, 2007 | 07:26 PM
SomeGoodBud2's Avatar
Default 93 del sol s SWAP
93 Del Sol S D15B7
I blew my engine...
I need to replace the d15b7 with an affordable..
b16a 88-91 sir I
- Motor
- Cable Tranny (Y1, S1, J1)
- ECU (PR3, PW0)
- Axles with Half Shaft
- Shift Linkage*
- Stock Motor Mounts*
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
- LSD Tranny (Optional +$300)
Aside from these items
what else do I need
A radiator? Hoses? Radiator stay?
How will a cable tranny work?
Will the stock mounts they provide match up?
I will need a different shift linkage?
Please help I need to do this by next week
Old Sep 8, 2007 | 07:54 PM
Hybrid96EK's Avatar
Default Re: 93 del sol s SWAP (SomeGoodBud2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SomeGoodBud2 &raquo;</TD></TR><TR><TD CLASS="quote">93 Del Sol S D15B7
I blew my engine...
b16a 88-91 sir I
- Motor
- ECU (PR3, PW0)
- Shift Linkage*
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
what else do I need
Please help I need to do this by next week </TD></TR></TABLE>
Cable tranny isn't going to do you any good. Your car needs a hydro. Spend a little more and get an Sir-II swap to keep things simple.
Old Sep 9, 2007 | 11:40 AM
Infinityzer050's Avatar
............and legal.
Old Sep 9, 2007 | 04:09 PM
Hybrid96EK's Avatar
Default Re: (Infinityzer050)
Since he is listed as being in Japan, I don't think the "legal" part would be that hard if he was to use the SIR-I swap. Its just that he is going to need to seperate and sell the tranny then find a hydro. For the time/work involved, might as well get a newer setup with less mileage.
Old Sep 9, 2007 | 06:45 PM
Default Re: (Hybrid96EK)
My new proposed setup
- Motor
- Hydraulic Tranny (S21, Y21)
- ECU (P30)
- Shift Linkage
- Stock Motor Mounts *
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
Koyo full rad
Samco hoses
do i have to run the rad fan, will the cooling be sufficient enough without it
1.)Will these axles work^?
2.)Where is the schematic for wiring the vtec in a non vtec car? It just uses the map? sensor signal, but i'm using the ecu from^ engine...
3.)Do i need mounts?
I am located in Arizona; Tucson is where I reside
Old Sep 11, 2007 | 08:42 AM
JdelMsolG's Avatar
Default Re: (SomeGoodBud2)
if you buy from hmotorsonline the axles will fit for sure, just make sure they know the car its going into. they also offer a deal on mounts by hasport. the swap comes with everything you really need minus shift linkage in some cases and "how to wire vtec" diagrams are all over honda-tech.
goodluck.
Old Sep 13, 2007 | 12:57 PM
Default Re: (JdelMsolG)
Good stuff, I think things are now taken care of. Thanks
I guess I'll post pics when ever I find my SD card reader
cody_sandlin
Aug 9, 2013 05:19 AM
Josueneta
Sep 13, 2010 04:34 PM
mikej94civex
Feb 7, 2010 05:40 PM
solsi2000
Feb 10, 2005 09:21 PM
93delsolboy
Jan 7, 2003 09:41 PM
