fan problems
Old Sep 8, 2007 | 05:20 PM
viciousef9's Avatar
Default fan problems
exactly what stuff is involved with the fan working. what exactly is consisted in it that function. anyone have pics.
Old Sep 8, 2007 | 05:49 PM
Crx Jimmy's Avatar
Default Re: fan problems (viciousef9)
the fan itself needs a ground and power to work, thats it
Old Sep 8, 2007 | 06:00 PM
gursh d's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">the fan itself needs a ground and power to work, thats it</TD></TR></TABLE>
yep. If your fan's not operating correctly,a good mod is to wire up a switch so you can always have it running when your car's on. Effective, cheap, easy mod.
Old Sep 8, 2007 | 06:05 PM
garageEF's Avatar
Default Re: fan problems (91.crx.si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91.crx.si &raquo;</TD></TR><TR><TD CLASS="quote">
yep. If your fan's not operating correctly,a good mod is to wire up a switch so you can always have it running when your car's on. Effective, cheap, easy mod.</TD></TR></TABLE> you forgot to mention ghetto
first of all be sure that the fuse is good. then test your fan by connecting it to direct power. if it doesn't work then its a bad fan. if it does then you need to check the fan relay or the fan switch on the back of the block.
Old Sep 8, 2007 | 06:06 PM
denraweb's Avatar
Default Re: fan problems (garageEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garageEF &raquo;</TD></TR><TR><TD CLASS="quote"> you forgot to mention ghetto
first of all be sure that the fuse is good. then test your fan by connecting it to direct power. if it doesn't work then its a bad fan. if it does then you need to check the fan relay or the fan switch on the back of the block. </TD></TR></TABLE>
Yup...what he said...
Old Sep 8, 2007 | 07:33 PM
viciousef9's Avatar
i changed the fan relay. where exactly is the fan switch. oh yeah i see that the fan is coming on now. but i also notice that is sometimes goes on and off. its weird.
Old Sep 8, 2007 | 07:39 PM
garageEF's Avatar
Default Re: (viciousef9)
its supposed to go on and off
Old Sep 8, 2007 | 09:08 PM
RCautoworks's Avatar
There is a fan relay, and a fan sensor/switch. The switch is located on the back of the block, there is also a relay I believe on the passenger side fender wall. I could be wrong though with the ef
Old Sep 9, 2007 | 01:58 AM
viciousef9's Avatar
i know the fan is suppose to go on and off. i mean it comes on for a second and then goes off. then it coes on for a couple of seconds and then goes off. then it will finally come on for the normal amount of time. the fan relay switch on the passenger side is behind the passenger side headlight. i dont know where the one is exactly in the back of the block.
Old Sep 9, 2007 | 02:01 AM
viciousef9's Avatar
dont reply if you gonna be sarcastic.
Old Sep 9, 2007 | 02:16 AM
garageEF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by viciousef9 &raquo;</TD></TR><TR><TD CLASS="quote">dont reply if you gonna be sarcastic.</TD></TR></TABLE>
i wasn't being sarcastic. how am i supposed to know from your "it comes on and off" description.
anyway, it sounds to me like the fan switch on the block. if you're under the car like your changing your oil it is to the left of the oil filter. it has a rubber boot on it with 2 electrical connections. replace that and let us know
killafred187
18
May 27, 2007 08:55 PM
mike93eh2
13
Feb 17, 2007 04:23 PM
iheartintegras
Aug 13, 2006 09:50 AM
92_EGhatch
11
Jan 26, 2006 02:02 AM
05em2
Jun 27, 2005 02:47 PM
