B18C1: OEM main and rod bearing questions
Old Sep 8, 2007 | 02:47 PM
=-JDM-EG-='s Avatar
Default B18C1: OEM main and rod bearing questions
I'm currently rebuilding my B18C1.
I asked a honda parts dealer in Singapore(asia) and they said that replacement bearings comes only in one size and has to be CNC machined to spec according to my rod and main's color codes. WTF?? I thought they are supposed to come with color codes or have i been mis-reading all this time. Can anyone clarify this?
Can anyone suggest an online shopping store where i can get the color coded bearings. Taking me days to actually source out where to buy.
thanks
Old Sep 8, 2007 | 03:12 PM
doood's Avatar
been there done that
Default Re: Oem bearing questions.. (=-JDM-EG-=)
aftermarket bearings like acl or king come in one size. usually equivalent to honda's green, or middle, bearing size. sometimes you get lucky and everything spec's out with these bearings.
oem honda bearings come in various colors (sizes) so you can mix and match to get precise clearances.
Old Sep 8, 2007 | 05:42 PM
=-JDM-EG-='s Avatar
Thats what i thought.
So any suggestion on where to buy the bearings online? I guess the only way is to buy it from the States coz parts here are not always available.
Old Sep 8, 2007 | 06:17 PM
XkjeldorX's Avatar
Default Re: (=-JDM-EG-=)
slhonda.com should have the bearings you need
Old Sep 9, 2007 | 06:07 AM
=-JDM-EG-='s Avatar
Thanks for the clarification and link...
Old Nov 28, 2010 | 12:15 AM
vteczone's Avatar
thanks
did u go to Kah Motor or just some parts dealer? bcoz Kah Motor do supply them. just that they mostly out of stock due to high demands.
Old Nov 28, 2010 | 09:54 PM
NotAJDMFanBoy's Avatar
Default Re: B18C1: OEM main and rod bearing questions
Usually the aftermarket bearings will spec out fine. If not, they do sell .01 oversized and .01 undersized bearings if you had a journal ground or going turbo and want more clearance. Or just buy OEM bearings. Or you can reuse your old ones.
purposebuilt
Jun 25, 2019 08:20 PM
streetsold6teeny8
Jun 1, 2010 03:02 PM
aznwash3wboi
Oct 3, 2005 09:57 PM
CRX T-Si
May 11, 2004 07:03 PM
philafelman
28
Sep 8, 2003 06:45 PM
