Engine Bearing clearance
Old May 11, 2004 | 11:06 AM
CRX T-Si's Avatar
Default Engine Bearing clearance
Damn it I can't remember who I got the bearings from.
Anyhow, I got the ACL beaing kit for my B16 and I was mearsuring the mains the other day(finally). I did the search and everyone's recommedations were 0.0015-17
These are the mains, don't have time for the rods yet.
#1 - 0.0015
#2 - 0.0015
#3 - 0.0011
#4 - 0.0015
#5 - 0.0014
What do ya'll think is this ok for FI??? Just worried about #3
Anyone know who I can call to get the one step looser???
Thanks
Old May 11, 2004 | 12:18 PM
boosted hybrid's Avatar
Default Re: Engine Bearing clearance (CRX T-Si)
#3 is on the tight side. It would be wise to purchase an OEM upper and lower main bearing to replace the ACL. The ACL bearings are approximately the same size as a green main bearing from Honda. Honda color coating works by allowing you to size a bearing larger or smaller by 0.0001" with each jump in color. Since you are at approximately a green now, you'll want to go to a pink or red. This will give you an extra 0.0002-4" clearance.
Old May 11, 2004 | 12:37 PM
CRX T-Si's Avatar
Default Re: Engine Bearing clearance (boosted hybrid)
So I can mix ACL with OEM main bearings??
Old May 11, 2004 | 12:45 PM
Its not optimal. Your choices at this point are going with all OEM or just doing one main.
Old May 11, 2004 | 01:22 PM
CRX T-Si's Avatar
Then OEM mains I must do. **** I see more money flying out of my pocket.
Now I just hope the ACL rod bearings are good, let me cross my fingers.
Old May 11, 2004 | 06:26 PM
Garcia-Racing's Avatar
leave the acls in and only replace the #3. It's ok to mix bearing. my .02.
Old May 11, 2004 | 06:35 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (TGARCIARACING)
ya acl's will put you around the middle , its better to do the oem thing
Old May 11, 2004 | 07:03 PM
m R g S r's Avatar
Default Re: (Hella_JDM)
I say run one red honda and check the clearances. If they are all fine then leave it. BTW, if you want a good deal on OEM bearings, call len, he is an awsome guy with great prices.
purposebuilt
Jun 25, 2019 08:20 PM
=-JDM-EG-=
Nov 28, 2010 09:54 PM
streetsold6teeny8
Jun 1, 2010 03:02 PM
bunnyrabbit
Mar 29, 2004 05:20 AM
