Eg hatch wont start
Ok there the problem is....turn the key and only fuel pump and click on the main relay is heard.....you press the clutch turn the key and acts like if you turn the key without the clutch engauged....starter is new.....grounds are good...might it be the ignition switch or?? please help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by curioso »</TD></TR><TR><TD CLASS="quote">you press the clutch turn the key and acts like if you turn the key without the clutch engauged</TD></TR></TABLE>
what exactly do you mean right here?
also, there is a switch under the dash, right at the clutch pedal. make sure it is not broken. sometimes they tend to break. also, if you have a voltage meter, take the switch out, and test it to see if it is bad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by curioso »</TD></TR><TR><TD CLASS="quote">well the clutch engauges but still no go.....</TD></TR></TABLE>
can you pop the clutch? you know push start the car?
also, check the switch i mention earlier. it's cheaper to check the switch and if bad replace than replacing the ignition switch.
if you have a voltage meter, take the lead and place the on the connector of the switch, then push the switch. if it grounds out on the meter then the switch is good, if not, then it's bad and most likely the problem.
you can also pick up these switches at any junkyard where manual hondas are.
95dc2teg
Jun 11, 2017 11:18 AM
99cpevtec
Jul 15, 2005 02:27 PM
