adjusting idle (4th gen)
Old Sep 8, 2007 | 02:07 PM
IAluder95's Avatar
Default adjusting idle (4th gen)
i just got my 4th gen back, and the idle is horribly wrong. i was curious how to set it back to the stock position? also where is the stock position? i left my service manual at my machine shop.
also the oil light only blinks when in neutral or at idle, but not in gear. any ideas why? oil sending unit?
Old Sep 8, 2007 | 02:55 PM
street_ride14's Avatar
Default Re: adjusting idle (IAluder95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IAluder95 &raquo;</TD></TR><TR><TD CLASS="quote">i just got my 4th gen back, and the idle is horribly wrong.</TD></TR></TABLE>
Take it back to the machine shop and have them fix the issues you're having. The idle is no big deal, Start the car, let warm up, remove IACV 2P connector, adjust idle by using the idle Adjusting screw on the TB, set to about 550 rpm, shut the car off, plug the IACV 2P connector, Reset the ECU, and start back up. You should should be 750-780 RPM after the reset.
Old Sep 8, 2007 | 03:36 PM
IAluder95's Avatar
no im doing the work to the car. its just i left it at my work.
ill go reset it now.
littledude56
Jan 22, 2010 10:01 AM
georgiajdm
Aug 11, 2009 06:31 PM
91 ef sedan
Dec 16, 2005 12:37 PM
'99luder
Apr 28, 2004 10:36 PM
JFG Kevin
Feb 22, 2004 09:59 PM
