HELP with 96 integra door handle
Old Sep 8, 2007 | 12:27 PM
acidvoodoo1's Avatar
Default HELP with 96 integra door handle
Can anyone tell me how to install a new outer door handle? I have the inside panel off, just can't figure out how to access the bolts on the handle throught the tiny opening on the inside???? Please HELP.......thanks
Old Sep 8, 2007 | 12:57 PM
Default Re: HELP with 96 integra door handle (acidvoodoo1)
anyone??? a little help???
Old Sep 8, 2007 | 03:12 PM
Dogginator's Avatar
Daisy... Daisy...
There are two 10mm bolts if I recall correctly. I don't recall it being difficult. Here is the diagram:
http://www.sonsacuraparts.com/...dIrno=
Old Sep 9, 2007 | 06:25 AM
Default Re: HELP with 96 integra door handle (Dogginator)
thank you!! the problem i'm running into is getting to those to bolts? the handle is surrounded by sheet metal with only a small hole to access it, i can't get my hand in there?
Old Sep 9, 2007 | 07:58 AM
Dogginator's Avatar
Daisy... Daisy...
I may have used an open end 10mm. I can't recall.
Old Sep 9, 2007 | 12:37 PM
bg-33p's Avatar
Attach a 10mm socket to a small extension and you should be able to hand unscrew the bolts. I think i may have even fit a socket wrench in there to get it out.
EG9_Sedan
Aug 31, 2015 06:28 AM
importfan85
Aug 20, 2008 07:30 PM
japspecb7
Jul 6, 2007 04:03 PM
andrewasf77
Feb 9, 2003 08:41 PM
SoloSol
Feb 4, 2003 03:31 PM
