IACV code after obd1 conv
Old Sep 8, 2007 | 10:53 AM
pokemon's Avatar
Default IACV code after obd1 conv
Idk if it is the cause of the problem but I usually keep my EF's obd0. Well in this case I used a jumper harness and the car starts and idles fine but I am getting the IACV code. I was wondering if this is because I am still using a resistor box with obd1 injectors? I know on an EG chassis when adding a resistor box you have to repin the IACV otherwise it will throw a code. Any info is appreciated TIA. - poke.
Old Sep 8, 2007 | 07:03 PM
pokemon's Avatar
ttt. - poke.
Old Sep 8, 2007 | 07:12 PM
Crx Jimmy's Avatar
Default Re: IACV code after obd1 conv (pokemon)
no it should work fine like that
99y8
Sep 9, 2012 09:31 PM
DEPintheCurve
Sep 26, 2008 04:07 AM
strawberry
Dec 18, 2007 04:35 AM
pj_baller00
Apr 16, 2004 08:07 AM
