Rubbing Noise From Rear Brakes
Old Sep 8, 2007 | 08:58 AM
LsHoney84's Avatar
Default Rubbing Noise From Driver's Side Rear Brake
Car: 95 Acura Integra Ls
Mileage: About 155k
Here's the situation,
i initially had uneven brake pad wear. I found that out when I heard the metal rubbing the rotor. The outer brake pad was hardly used (still was perfectly good to use), whereas the inner brake pad had a big amount of padding left on one side and the other side was gone to the metal.
well, i saw that one of the slide pin/bolts was seized. I couldnt take it out so I just replaced the whole mounting bracket and put new brake pads.
Still i hear rubbing. It sounds like my brake pads are just rubbing/riding the rotors.
I know i dont have to replace the caliper (or do I?) because i could easily turn in the piston into the caliper.
Now for my question in solving this problem,
would overtorquing the bolts that go into the slide pin/bolt cause the brake pads to ride/rub the rotor?
Help me out fellas and ladies
accord0411
Oct 10, 2007 01:51 PM
.brian.
Mar 27, 2007 12:40 PM
Jap_Spec_Imports
Nov 25, 2006 04:09 PM
OEMcivic
Dec 22, 2004 11:58 PM
AMG
13
Aug 18, 2004 09:03 AM
