Brake Question
Brake Question
When my car drives the drvier side brake is squealing. When I put my car on the lift and rotated the tire it felt like the brakes were rubbing on the brake pad. What can this be from? Its also making an annoying squealing noise.
Re: Brake Question (APCforthewin)
you probably need to replace your pads.. or it could be the shims on the bracket that are rubbing.. if you can spin your wheel and it has the same resistance as the other side the caliper is not sticking.
Re: Brake Question (jdeemseerx)
once brake pads get so far down , they have a piece of metal that rubs your rotor , giving off a sqealing noise to let you know they are almost gone.
roundworldsobig
08-26-2006 06:12 PM
