Fuel rail leaking...... Whats wrong?
Old Sep 8, 2007 | 08:27 AM
SneezinCD5's Avatar
Default Fuel rail leaking...... Whats wrong?
I am installing my OEM fuel rail and now that its back on, it has a leak coming from one of the injectors. I can't remember if they were snug or not before I took the rail off but now they seem like they are loose. I am able to move them. The O ring's are inplace and the rail is tight. How am I able to fix this? Would a new O ring kit work?
Old Sep 8, 2007 | 08:51 AM
SneezinCD5's Avatar
Default Re: Fuel rail leaking...... Whats wrong? (SneezinCD5)
C'mon someone atleast reply to me
Old Sep 8, 2007 | 09:28 AM
thesmogman's Avatar
Well if that is where they are leaking from.
I would of done them while I had it off in the first place.
You probably pinched one of them o-rings. I coated the new seals with oil so they would slip in easier.
Old Sep 8, 2007 | 09:29 AM
HeikDiesel's Avatar
Default Re: Fuel rail leaking...... Whats wrong? (thesmogman)
I was always told any time you disturb an o-ring to replace it. Sometimes they seal and when you re-install them they wont even if you dont cut them.
410ruga
Apr 10, 2014 03:46 AM
10sec4door
Jul 11, 2010 08:46 AM
naptownrex
Feb 1, 2005 08:21 AM
JoshRambo
Sep 16, 2002 03:54 AM
