b20 swap tomorrow, tranny question please!
Old Sep 7, 2007 | 09:02 PM
unrealgtx's Avatar
Default b20 swap tomorrow, tranny question please!
hey guys i got my b20b today ,finally. well im planning on swapping it with a friend tomorrow morning .this is my first time doing this(but he has several times). ive done some research for the past 2 weeks and found that it actually isiint that hard the only thin im concerned about is does the tranny bolt on as is or does it have to be on a certain way , any other tips or pointers would help a bunch so i dont completely ruin my car .
also, will that tutorial on at cspeedracing on the eg b18c swap help for any of this
http://www.c-speedracing.com/h...p.php
thanks a bunch
edit: i have a 91 ls with a b18a1
Old Sep 7, 2007 | 10:01 PM
toofast4u752's Avatar
im not sure what you mean about does the tranny bolt on as is??? and yes it has to be right side up and shaftside to the motor... if your asking is there anything special about mounting to the tranny to a once automatic b20? then no bolts just the same... not much else to tell you... you just gotta know how to wrench....
Old Sep 7, 2007 | 10:09 PM
LordAphotic's Avatar
ur going to be using the same tranny so it will fit the the chassis the same...
and the b20 is the same thing as the ls in terms of design except of the 84mm bore...
so it will all bolt up like stock... the only problem u might have is the mount on the timming belt side might need to be swapped out depending on what b20 u have. but u can just use the one from ur original engine.
i have 2 b20s.
Old Sep 7, 2007 | 10:28 PM
unrealgtx's Avatar
Default Re: (LordAphotic)
oh yeah i knew about the mount thingy , as far as the tranny goes im just going to take it off my b18 and put in on my b20 no matter what positioon its in ..... so yeah also how can i take off the thing that holds on the ac belt power steering belt. without power tools? kinda hard i think
Old Sep 7, 2007 | 10:35 PM
dude u live in whittier ca... i do too.
where are u located. i cant help too much cause i have heart problems but i can give us advice now and then.
Old Sep 7, 2007 | 10:40 PM
unrealgtx's Avatar
i live by a middle school off norwalk blvd. if u go by the taco bell off whittier and norwalk and make a right going toward like that little liquor store im just a couple blocks down by the middle school if u know what im talking about .......
Old Sep 7, 2007 | 10:54 PM
doood's Avatar
been there done that
Default Re: (unrealgtx)
im assuming you already got a new clutch and flywheel for the b20? or at least reusing the one's off your old b18.
Old Sep 7, 2007 | 11:04 PM
unrealgtx's Avatar
Default Re: (doood)
yea i got a new tranny on the b18a ,well rebuilt but yeah everything is new except my b18a , it blew so yea thats why i got the b20 just need help installing
Old Sep 7, 2007 | 11:45 PM
oh i know where u live.. ur pretty far from me im south side whittier.
i know where u live though if u want on sunday or monday i can come give u some advice and show u my swap.
Old Sep 8, 2007 | 12:38 AM
unrealgtx's Avatar
tight im down for sunday
Old Sep 8, 2007 | 08:23 PM
unrealgtx's Avatar
bump, hey i got it all out and everything is on my b20 now, the only thing is im missing a few things..... in the back of the b18a theres a black box from the top block to the bottom which is not on the b20 ,the b20 is also missing a 2 prong plug thing thats in the back of the b18 , theres also some sensor missing i am told. so idk what to do right now . if anyone also knows a good solid way of putting everything back in order ( as far as wires and hoses for the b20 )because i dont wanna miss something when i put it all back in my engine bay and have to take it all out .
Old Sep 9, 2007 | 01:34 AM
unrealgtx's Avatar
bump
swepper
Feb 15, 2009 06:59 PM
unrealgtx
Sep 8, 2007 06:11 PM
BoltonGSR
Feb 1, 2007 05:15 PM
Itzmy91Teg
Jun 9, 2006 11:49 AM
