Heater Issues in 97 Cx Hatchback
Old Sep 7, 2007 | 08:18 PM
hennessy's Avatar
Default Heater Issues in 97 Cx Hatchback
It is not the blower motor or stuff in it because i just replaced it. (Makes an annoying loud buzz when ever i turn the heater on). I turn the heater on and i can barely feel anything even when its at the highest level...Can someone please tell me what the problem is? Fall is around and its getting pretty cold....TIA
Old Sep 8, 2007 | 05:10 AM
RyanA's Avatar
Default Re: Heater Issues in 97 Cx Hatchback (hennessy)
Sounds like you may have a ton of leaves in the cowl or intake ductwork. Also check the damper door just to make sure it's moving...
Old Sep 8, 2007 | 05:58 AM
instrument's Avatar
did the car sit for a while?
after my CRX sat for a few months after getting hit, and me being utterly depressed, it had a ton of leaves and **** blocking it...had to clean it out.
Old Sep 8, 2007 | 11:11 PM
hennessy's Avatar
Default Re: (instrument)
wait where is the cowl or intake ductwork?
Old Sep 9, 2007 | 05:42 AM
RyanA's Avatar
Default Re: (hennessy)
You usually can just pull your blower motor out, located under the passenger side dash by the kickpanel, and you can get it from there. Otherwise, the cowl is the black plastic piece between the engine compartment and windshield. It comes off by taking off the windshield wiper arms and a few plastic clips.
Ryan
Old Sep 9, 2007 | 08:26 PM
hennessy's Avatar
Default Re: (RyanA)
ok i did that and my heater is still not working...any other causes?
rolltidejb2
Mar 4, 2016 03:37 PM
XYFLZ
Jul 18, 2010 06:49 AM
Ineed$
Sep 14, 2009 02:13 PM
JDM honey
15
Oct 8, 2007 10:18 AM
