My brakes gave out
Old Sep 7, 2007 | 08:00 PM
Nocturnal's Avatar
Default My brakes gave out
I was driving home and I noticed my brake pedal could be pushed too the floor. I had to pump it in order to brake properly. What could have gone wrong? Is this a symptom of anything? Thanks!
My car is a 93 Si hatchback and I changed my brake pads about six to eight months ago. I haven't changed the master cylinder. Could my MC have gone bad?
Old Sep 7, 2007 | 08:21 PM
BlueIntegraBoy's Avatar
Default Re: My brakes gave out (Nocturnal)
Yes, your master cylinder could have gone out.
Old Sep 7, 2007 | 08:28 PM
Nocturnal's Avatar
If you guys don't mind, may I ask how much on average does it cost to replace a MC?
Old Sep 7, 2007 | 08:29 PM
Default Re: (Nocturnal)
You can get a used one pretty cheap. eBay has OEM replacement ones cheap and you can put it on.
Old Sep 7, 2007 | 08:31 PM
instrument's Avatar
1. your icon is freaking me out
2. did you bother to check the fluid level?
3.if so and its not low, then it is most likely you MC.
it's easy to replace yourself.
Old Sep 7, 2007 | 08:32 PM
Nocturnal's Avatar
Default Re: (instrument)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument &raquo;</TD></TR><TR><TD CLASS="quote">1. your icon is freaking me out
it's easy to replace yourself.</TD></TR></TABLE>
Yes sir. Checked fluid levels and it's the same. Thank you.
Old Sep 7, 2007 | 08:49 PM
Archidictus's Avatar
Unceasing Measure
I've also replaced blown brake boosters before. Does your idle do anything when you press the brake pedal? Also, have you checked all four corners to make sure fluid isn't going anywhere? Lastly, did you bleed your lines really well when you did your pads. I know you said it started happening in the middle of driving - and that's 95% a master cylinder problem - but it's nice to get other options out of the way
Old Sep 7, 2007 | 09:23 PM
hondamark35's Avatar
the master is the most likely part to fail in my experience. before you buy anything make sure that all of you lines look good esp. the rubber lines to the calipers/wheel cylinders to be sure you have no leaks. if you see dampness under the master cyl on the booster, tale-tell sign that the MC is bad.
as far as price, i don't think it will break the bank. also this is a part i would splurge on. you will get your dollars worth. when you put the new one on make sure you follow the right procedure for bleeding the MC and the lines.
it's not hard, you just have to do it.
93grayeg
Aug 25, 2010 11:58 AM
s10cky
17
Dec 20, 2006 07:19 PM
AnthonyG2003
Jul 24, 2005 11:37 AM
ironballz
Apr 30, 2004 10:17 PM
