Wierd whistling noise......help!
Old Jun 15, 2002 | 10:18 PM
Petah's Avatar
Default Wierd whistling noise......help!
I noticed my car has developped a wired whistling noise. I when i press the clutch down, the noise goes away but when the clutch it's up, the whistling comes back. Now this is done in neutral so i know it's something with the clutch or the tranny. It kind of sounds like a AEM sucking air in at idle. It's a bearing going in the tranny? Does anyone know? Thanks
BTW - i have a 94 GSR motor in my car (no LSD)
Old Jun 15, 2002 | 11:06 PM
hybridreams's Avatar
Default Re: Wierd whistling noise......help! (eg-six)
I'm thinking maybe something with the flywheel? Guessing here.
Either way, if you know for sure its something in the transmission, its gonna have to be taken off. I would just stop worrying and take it to a shop to have them take the transmission off to see what the problem is.
Old Jun 16, 2002 | 12:55 PM
SpoolinSol's Avatar
It's quite possible it's the throwout bearing... Mine makes an annoying whistling noise..... it's been making that noise since my clutch was replaced a while ago.... haven't bothered with it since it's more of a nuisance then a problem..... You may want to get a shop to check, just to make sure...
Take care ....
Old Jun 16, 2002 | 05:25 PM
Petah's Avatar
Default Re: Wierd whistling noise......help! (SpoolinSol)
Take care ....
Is the throw out bearing part of the tranny or the clutch or another part?
Old Jun 16, 2002 | 05:27 PM
WHATS VTEC's Avatar
the throw out bearing slides inside the middle of the clutch inside of the tranny, thats how mine was, and if it is not that it has something to do with the tranny cause it will not do it when the clutch is in! good luck
Old Jun 16, 2002 | 06:21 PM
Petah's Avatar
Default Re: Wierd whistling noise......help! (low93ex)
So i wouldn't need to open the tranny to fix the throwout bearing?? Also, can i drive like that? I am going lapping this weekend...the whole weekend...do you think it will last?? If not, i am not going to bring my car. Thanks
Old Jun 16, 2002 | 06:25 PM
WHATS VTEC's Avatar
you have to take the tranny off the block in order to fix it, it wiill get reall loud when it is close to going out, i drove on mine for a long time...
Old Jun 16, 2002 | 07:55 PM
Petah's Avatar
what happend if the throw out bearing dies on me? Can't get into gear??
Old Jun 16, 2002 | 08:02 PM
owen_the_soyboy's Avatar
yes the bearing can shred itself and spew metal chunks into your pressure plate and clutch disk, also harming your flywheel.
the tell tale sign of the release/throwout bearing is the fact that the noise is on or off depending on when the clutch pedal is in or out.
the bearing is easy as pie to replace since you do NOT need to split open the tranny.
But you have to drop the tranny to replace the bearing... so you might want to get that lightweight flywheel or new clutch you always wanted since you will need to drop the tranny for those installs too.
or switch to a Civic Si tranny.. shorter gearing =
Old Jun 17, 2002 | 08:42 AM
Petah's Avatar
Default Re: Wierd whistling noise......help! (owen_the_soyboy)
Ok...i just got off the phone with the shop that did my swap. They are saying if the throwout/release bearing is bad, it will only make whinning noises if you are ON the clutch, not off. But right now, whenever my clutch pedal is down (pressing the pedal), the noise goes away and the pedal is up (not pressing it), the noise returns. Could this still be a bad throwout bearing??
[Modified by eg-six, 8:12 PM 6/20/2002]
Old Jun 17, 2002 | 08:44 AM
Spade's Avatar
With the tranny making noise while I had the clutch out (foot off the pedal), it was my imput shaft bearings.
Old Jun 20, 2002 | 07:12 PM
Petah's Avatar
Default Re: Wierd whistling noise......help! (Spade)
Anyones else?
Old Jun 20, 2002 | 08:57 PM
HarryB's Avatar
From: Where All Funky Things Come From...., Stankonia, USA
Im having the same problem and I have been running my car for a while with it. Its starting to sound really bad. My syncro is also screwed because my gears grind from 2nd to 3rd. I think im going to put a DX tranny from my friends 98 DX (free). I know its has taller gears but how bad will it be? I know that I will be in boost longer but I think I will loose alot of acceleration? What do you guys think?
Sorry i kinda changed the subject eg-six
93S0L
Transmission & Drivetrain
Sep 14, 2008 03:52 PM
JDMtype Eg6
May 29, 2006 03:45 AM
JDMtype Eg6
Apr 4, 2006 08:55 PM
Razor
Honda S2000
Nov 11, 2003 08:41 AM
garados
Feb 3, 2003 11:08 AM
