any1 know brakes????? 00' si
Old Sep 7, 2007 | 06:16 PM
civicpark81's Avatar
Default any1 know brakes????? 00' si
hey wats up guys. i recently did a pad swap on my 00' si and when i put it back together the caliper piston pinched the boot or seal. honda has a repair kit, but i wanna c if ne1 knows how to do the repair. any 411 would be helpfull
Old Sep 7, 2007 | 07:39 PM
IMALLSLO's Avatar
Default Re: any1 know brakes????? 00' si (civicpark81)
Its not to difficult but I recommend the use of compressed air to install the piston after the boot is on. If you dont have compressed air it might be a bit harder. The seals go on and off faily straight foward.
Heres the quick version:
Remove caliper assembly
Remove piston from caliper
Remove old torn boot
Remove seal from caliper
Clean piston
Install new seal and apply supplied grease to seal and piston
Install new boot
Place piston at oppening of boot and hold tight
apply compressed air to brake line hole(you need a blower with a rubber end to seal good) and same time gently push piston in.
The boot should balloon around piston
Slide the rest of the piston in,assemble on car and bleed system
Hope this helps
Old Sep 9, 2007 | 12:21 PM
Default Re: any1 know brakes????? 00' si (IMALLSLO)
hey bro u wouldnt happen to have any illustrations by any chance do u????
Old Sep 9, 2007 | 02:50 PM
IMALLSLO's Avatar
rebuild tutorial here
Old Sep 9, 2007 | 03:06 PM
1992Si's Avatar
Have you check out the cost of a rebuilt caliper at the auto parts store. If your going thought all the trouble to remove the caliper and only change the seal, you might as well replace the caliper.
Old Sep 9, 2007 | 05:50 PM
EJ8mike's Avatar
Default Re: (1992Si)
^what he said
i got a rebuilt autozone caliper for only $50 with returned core, it doesn't have that nice anti-rust coating like the honda ones do though.
jdmbm
Suspension & Brakes
Aug 15, 2014 10:32 AM
Str8 outta Cliff
Suspension & Brakes
Jul 22, 2009 03:28 PM
tlmadness
Jul 7, 2007 04:58 PM
hondmywrld
Apr 2, 2007 10:15 PM
shutta
Mar 29, 2006 06:01 AM
