raptor shift light problem
Old Sep 7, 2007 | 06:02 PM
crxrider's Avatar
Default raptor shift light problem
hey guys bought a raptor shift light, its grounded, and powered right but for some reason when i rev it it bounces of a rev limiter at like six grand. its a zc dohc the light signal is ran of the blue wire off the dizzy which is the negative wire i believe what could it be? is the black and yellow wire the negative? anything else anyone can think of? any help appreciated.
Old Sep 7, 2007 | 06:31 PM
STREETWERKZ's Avatar
Default Re: raptor shift light problem (crxrider)
this might be a weird question....
does the light not turn on when free revving it in the driveway?
try driving it down the street. those funky brand gauges sometimes dont work unless in motion.
also, check the bulb, sometimes they burnout during installation if you dont run an inline fuse.
Old Sep 7, 2007 | 06:43 PM
crxrider's Avatar
Default Re: raptor shift light problem (STREETWERKZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote">this might be a weird question....
also, check the bulb, sometimes they burnout during installation if you dont run an inline fuse. </TD></TR></TABLE>
it revs in driveway but ends up hitting a rev limiter or someething. it works in motion buy only till 6000 rpm, the bulb is good, i was right on the blue wire being the negative wire right? i am kind of lost.
Old Sep 7, 2007 | 06:50 PM
abram_quito's Avatar
ITS OKAY IF IT LIGHTS
IF ITS CEL THEN WORRY
POWER IS EVERYTHING
DO NOT LET LIGHTS FOOL U
MAY BE A SHORT CIRCUIT
EITHER SERIES OR PARALLEL CIRCUIT
CHECK DIAGRAMS
Old Sep 7, 2007 | 07:01 PM
crxrider's Avatar
i dont understand a thing you just said, anyone else?
Old Sep 7, 2007 | 08:36 PM
check wiring schematics
and obtain voltmeter
check series and parallel short circuits
Old Sep 7, 2007 | 09:00 PM
Tippyman's Avatar
Default Re: (abram_quito)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abram_quito &raquo;</TD></TR><TR><TD CLASS="quote">ITS OKAY IF IT LIGHTS
POWER IS EVERYTHING
CHECK DIAGRAMS</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abram_quito &raquo;</TD></TR><TR><TD CLASS="quote">check wiring schematics
Dude, wtf?
Old Sep 7, 2007 | 09:20 PM
RoadconeTuning's Avatar
Default Re: (Tippyman)
ive got a raptor in my mustang and it works great, you just have to hook the signal up to the right signal source...
high quality part and works great if installed correctly... just find a pinout on the connector for you dizzy and find your tach signal... or do like i did and tap off of the signal wire leaving your ECU...
Old Sep 8, 2007 | 06:28 PM
crxrider's Avatar
can anyone tell me what color the wire for tach signal coming off the ecu is?
Old Sep 9, 2007 | 12:36 PM
crxrider's Avatar
anyone?
Old Sep 9, 2007 | 12:53 PM
denraweb's Avatar
Default Re: (crxrider)
Why don't you search a pin out for your ecu, it will tell you in the pin out diagram...
Old Sep 10, 2007 | 01:18 PM
crxrider's Avatar
searched and cant find the diagram anyone got one?
Old Sep 11, 2007 | 07:17 AM
if you cant find that then you don deserve to have a shiftlight...
either here on H-T or goto the Apex'i site and look for a VAFC manual... pin out is in there for most ecus.
SlowHX
13
Sep 6, 2005 03:52 PM
ANVIL
May 15, 2004 08:14 AM
ViXoN Hatch94
Feb 29, 2004 11:46 PM
trutuner
May 25, 2003 06:37 PM
arcboy
Jan 10, 2002 05:59 PM
