TWM itbs Stick open while idling to 1200rpms.
Old Sep 7, 2007 | 05:20 PM
IntegraType-R's Avatar
Default TWM itbs Stick open while idling to 1200rpms.
It only happens after the car is warmuped to normal temp. When the car's cold i can blop the throttle and it'll go back down to 900rpms. After the car is warmup. If i get on it alittle bit, and come to idle, it goes to 900, then climbs back up 1200rpms, yes i've tried the extra spring on the plate and also on the other side of the itbs, is it a vac leak or is there anything i can do?
Old Sep 8, 2007 | 02:06 PM
stock ek's Avatar
Default Re: TWM itbs Stick open while idling to 1200rpms. (IntegraType-R)
i would say check some vac lines
e30FTMFW
Nov 18, 2008 11:52 AM
neldogg
Nov 17, 2007 03:52 PM
deeweezy187
Dec 3, 2005 08:50 PM
crx1racing
May 29, 2005 04:36 PM
Teknic73
Nov 7, 2003 01:30 PM
