head bolt strectch?
Old Jun 15, 2002 | 09:48 PM
the DR.'s Avatar
Default head bolt strectch?
i put together a mini me and it started to overheat, when i went to pull the head back off the upper 3 in the middle (headbolts) were loose, like i can turn them just with my hands, the headbolts were used before, how many times i do not know, my question is will the headbolts come loose due to stretching? or was it another problem altogether, i'm waiting til monday when i can pick up some new ones, and i'll put some locktite this time around, i didnt last time, but didnt think it was necessary. anyone have any info?
Old Jun 15, 2002 | 10:20 PM
the DR.'s Avatar
Default Re: head bolt strectch? (CIVICtypeS)
forgot to mention..
d15b2 block (91 dx)
d16y8 head (96 ex)
y8 head gasket, head is milled .040"
Old Jun 15, 2002 | 10:36 PM
Malgerus's Avatar
hmm. Headbolts do stretch a little, but they should not stretch that much. I guess new bolts and loctite will probably work, but if you're really worried, get ARP bolts.
Old Jun 15, 2002 | 10:39 PM
the DR.'s Avatar
Default Re: head bolt strectch? (89_Y_49)
i cant really wait any longer on ARP bolts, its running higher compression than before, i'm just worried about it coming loose again, and will they come loose if they are stretched?
Old Jun 16, 2002 | 02:02 AM
RexB16's Avatar
heat and stress warp the bolts. you are never supposed to reuse head bolts
Old Jun 16, 2002 | 06:07 AM
Chiovnidca's Avatar
Don't use locktite on your headbolts. How bad did you overheat it? The head is probably warped.
White_EG1
Dec 13, 2015 08:12 AM
holmesnmanny
Aug 29, 2010 02:23 PM
simplypinoyy
May 23, 2004 02:43 PM
Boost2NA
Jul 16, 2003 01:46 AM
Goldfingiz
Dec 9, 2002 02:08 PM
