Difference in gsr and LS oil pans
Old Sep 7, 2007 | 03:41 PM
Avenged7x's Avatar
Default Difference in gsr and LS oil pans
Is there a difference in size or anything between the oil pans in the GSR and LS models?
Figured there would be a thread somewhere on this but nothing came up in the search, maybe im just over worried and is a stupid question
Old Sep 7, 2007 | 04:13 PM
frankenstienEk's Avatar
Default Re: Difference in gsr and LS oil pans (Avenged7x)
don't think so because the other day i just bought a oil pan gasket from acura and told the counter person if he can check if the ls and the gsr are the same gasket and he said they are . If the gasket is the the same, i don't see why they would be different
Old Sep 7, 2007 | 04:14 PM
CleanLikeJdm's Avatar
Hype-R Stalker
..Yes, there is a Huge difference, of course the bolt pattern is the same.
GSR pan is deeper Because of the block girdle, meaning the LS pan will be More shallow.
Old Sep 7, 2007 | 05:21 PM
LoseRPunKx182's Avatar
Default Re: Difference in gsr and LS oil pans (CleanLikeJdm)
^^he pretty much sum it up, they're different.
Old Sep 7, 2007 | 05:25 PM
Avenged7x's Avatar
Default Re: Difference in gsr and LS oil pans (LoseRPunKx182)
thank you sir
Old Sep 7, 2007 | 07:10 PM
alexisthemovie's Avatar
ls and gsr oil pans are different but the gsr and itr share the same part.
Old Sep 13, 2007 | 11:33 AM
g2_teg_'s Avatar
Default Re: (alexisthemovie)
im pretty sure ITR/GSR have more baffles in the oil pan too. i could be wrong.
Modified by g2_teg_ at 1:14 PM 9/14/2007
Old Sep 13, 2007 | 11:40 AM
kpop's Avatar
Default Re: (g2_teg_)
their different.
Old Sep 13, 2007 | 08:02 PM
g2daturbo's Avatar
Default Re: (kpop)
def different but u can run the gsr oil Pan on a ls if u use the gsr pickup. on the other hand the ls will not work on the gsr... seen this happen before, not good things ....say goodbye to ur internals
Old Sep 13, 2007 | 08:57 PM
doood's Avatar
been there done that
Default Re: (g2daturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2_teg_ &raquo;</TD></TR><TR><TD CLASS="quote">im pretty sure ITR/GSR have more baffles in the oil pan too. i could be wrong.</TD></TR></TABLE>
stock pans are not baffled
Old Sep 14, 2007 | 12:14 PM
g2_teg_'s Avatar
Default Re: (doood)
then i was wrong...i dont know where i heard that.
lurkin' eg
Feb 18, 2008 07:15 PM
Civiclx
Nov 12, 2007 06:27 PM
esoterEK..
Feb 22, 2007 09:36 PM
Turbotype
Feb 21, 2005 11:15 AM
SLOW EF8
Jul 17, 2003 04:14 AM
