1 wire oxygen sensor to 4 wire oxygen sensor on civic cx
Old Sep 7, 2007 | 03:14 PM
B18CivicEH2's Avatar
Default 1 wire oxygen sensor to 4 wire oxygen sensor on civic cx
on my b18b civic cx, i have a engine harness with a 4 wire o2 sensor plug. according to this link, i only have to modified my old harness which had a 1 wire o2 sensor plug.
http://www.hybridautomotive.com/tech/o2/
but since my harness has the 4 wires one, can i just plug the oxygen sensor in to delete my code 41, or will i have to do anything with the harness that goes from the shock tower into the cabin to the ecu??? i tryed searching and couldnt find anything....thanks in advance
Old Sep 9, 2007 | 10:05 PM
Default Re: 1 wire oxygen sensor to 4 wire oxygen sensor on civic cx (B18CivicEH2)
bump
Old Sep 9, 2007 | 10:10 PM
Archidictus's Avatar
Unceasing Measure
If you have a four-wire harness plug and you have a four-wire sensor, you're good to go.
Old Sep 9, 2007 | 10:16 PM
Ex-Eg-Driver's Avatar
nice swap choice!
Old Sep 10, 2007 | 07:10 PM
Default Re: 1 wire oxygen sensor to 4 wire oxygen sensor on civic cx (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">If you have a four-wire harness plug and you have a four-wire sensor, you're good to go.</TD></TR></TABLE>
thanks...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NINJA-EG &raquo;</TD></TR><TR><TD CLASS="quote">nice swap choice!
thanks!!!yea...it has some work done into it so its chill...im still debating on if i should just finish my NA lsvtec, or if i should sell my fully built head and go boost....but that a whole different topic..
KidRuthless
Mar 19, 2014 01:07 AM
stackz
13
Nov 8, 2007 10:49 AM
JLefevers
18
Sep 19, 2007 03:17 PM
DevineCRX
Jul 18, 2002 07:31 AM
