crank pulley bolt....
Old Jun 15, 2002 | 09:25 PM
BoostedED9's Avatar
Default crank pulley bolt....
well recently for some reason my crank pulley bolt has been backing itself out and tis pissing me off..... does anyone know what i can do to tigten it down without having the special crank pulley tool so it doesnt spin??? sometimes i have to tighten it up everyday before heading out to work. any solution to this i would really apreciate
thanks in advance...
Old Jun 15, 2002 | 09:28 PM
CimorelliCRX's Avatar
Default Re: crank pulley bolt.... (ED9Hybrid)
Lock the flywheel, stick like a screwdriver through where hte dustcover is(i dont have mine for this reason, lol), and when you get it locked in, then tighten it, you should be able to get it as tight as it will go that way. Same for removing it..
Old Jun 15, 2002 | 10:28 PM
the DR.'s Avatar
Default Re: crank pulley bolt.... (CimorelliCRX)
u can pull out the starter or the dustcover mentioned earlier, and hold the flywheel then tighten it, or swing by a local shop and ask to borrow an air gun really quick and give the bolt a good hit
Old Jun 15, 2002 | 10:32 PM
Malgerus's Avatar
Is that the dustcover on the bottom of the tranny, where it mates to the engine? You don't have yours on? Wouldn't the flywheel and the clutch assembly rust when water gets in there??
Old Jun 16, 2002 | 02:13 AM
RexB16's Avatar
Default Re: crank pulley bolt.... (89_Y_49)
u sure the bolt is ok?
Old Jun 16, 2002 | 05:08 AM
BoostedED9's Avatar
Default Re: crank pulley bolt.... (RexB16)
i dont see hwat would be wrong with the bolt...
so i should stick a screwdriver or something and jam up the flywheel hten tihgten up???
Old Jun 16, 2002 | 06:45 AM
it dont get much water in there, it dont rain much in texas... its kinda like brake rotors, they will rust till the first time the breaks him em, and its gone..
1 sLoW hAtCh
Jun 1, 2008 10:07 AM
88 dx
13
Aug 19, 2005 10:30 AM
kid_layzie
Apr 2, 2004 09:52 AM
warwagon
Mar 10, 2003 09:29 AM
