Is it just me ir the headlights bracket for the USDM and JDM are the same ?
Old Jun 15, 2002 | 09:01 PM
Flamenco-T's Avatar
Default Is it just me ir the headlights bracket for the USDM and JDM are the same ?
I was able to compare both radiator supports and I kinda doubt it but both headlights bracket on the USDM and JDM are the same, same dimension, size and etc...
I was just curious, since I am trying to find the easy way to swap the radiator support...
anybody can confirm this ?
Old Jun 15, 2002 | 09:39 PM
uNF$@#!'s Avatar
Default Re: Is it just me ir the headlights bracket for the USDM and JDM are the same ? (Flamenco-NA)
swap radiator supports...if you knew anything about the support you would realize your answer?
you COULD skimp out on the rad support and just drill the appropiate holes for it and pray the front end works, but then, where would you mount the bumper support?
"cheaters never prosper, try to sit on general make general lose face" - mel gibson lethal weapon 4
[Modified by 00-0187, 1:45 AM 6/16/2002]
Old Jun 16, 2002 | 10:19 AM
Flamenco-T's Avatar
Default Re: Is it just me ir the headlights bracket for the USDM and JDM are the same ? (00-0187)
okay, whatever...thanks for nothings...
BTW, I have both radiator supports and was trying to make a lil observation
Old Jun 16, 2002 | 11:15 AM
sgT's Avatar
sgT
I lost the diagram, but the core support is like 5-6 pieces.
Some are the same and some are different. cant remember which are though
Old Jun 16, 2002 | 06:59 PM
t's Avatar
t
If you have both radiator supports, use the JDM one.
The JDM hood wont close over the U.S. top piece. The middle portion of the radiator support(JDM) is where the hood latch would go. The two side pieces of the radiator support(JDM) have provisions for the bumper beam and bumper support bracket. The other piece(bottom of support) is the same as U.S. spec.
Old Jun 16, 2002 | 07:04 PM
uNF$@#!'s Avatar
.... and i was giving you advice. I really didnt mean anything else by it.
where would you mount the bumper support? why skimp out on the radiator support? you would need alot of modification to the usdm rad support.
[Modified by 00-0187, 11:10 PM 6/16/2002]
Old Jun 16, 2002 | 07:28 PM
JDMITR222's Avatar
I was just curious, since I am trying to find the easy way to swap the radiator support?.
No easy way around it, unless you want to cut the crap out of your car and then it still won't fit right.Just take your time and do it right don't rush it it's not worth it.
Justin
Pro-Am 1934
Oct 27, 2008 02:48 AM
roy.jovero
Jul 18, 2005 12:07 AM
Rotary knight
Apr 17, 2005 10:29 PM
2000 Integra R #760
Sep 27, 2003 07:53 PM
98cwtypeR
Feb 25, 2003 09:04 PM
