Injector leaks after an EGR port cleaning?
Old Sep 7, 2007 | 07:34 AM
acuteviet's Avatar
Default Injector leaks after an EGR port cleaning?
Hey H-T guys,
After doing an EGR port cleaning on my 5th gen., I started to smell fuel odor.
I followed like the article stated on accord (FAQ). Ran the car after I put everything back and it was fined. This morning, I started the car for a warm up to head to work. After awhile I smell fuel odor so I just turn off the car and will fix it after work today.
The article stated that he didn't take out the injectors from the manifold because of this I don't think the injectors sat well on the fuel rail. Maybe I can take the injectors and sit it in the fuel rail first then the manifold.
Any methods are welcome!!!
Modified by acuteviet at 9:07 AM 9/7/2007
Old Sep 7, 2007 | 08:01 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Injector leaks after an EGR port cleaning? (acuteviet)
a friend had this happen after he cleaned his egr ports on his 94 EX. He just went to Honda and ordered new o-rings for the injectors and replaced them. No more fuel leak.
also, just an fyi, the injectors dont sit in block, they sit in the intake manifold and fuel rail.
Old Sep 7, 2007 | 08:07 AM
acuteviet's Avatar
Default Re: Injector leaks after an EGR port cleaning? (TouringAccord)
I figured it would be easier to understand that way then the manifold. Thanks for the info. will change it...
Old Sep 7, 2007 | 08:39 AM
guymontag's Avatar
I had this problem. I pinched two of the O-rings that seal the injectors to the fuel rail 'cause I didn't follow directions. You've gotta put the injectors in the fuel rail first, and then put the rail/injectors back onto the manifold. Double-check whether you damaged any of those O-rings, k? Don't need any engine fires.
Old Sep 7, 2007 | 11:28 AM
acuteviet's Avatar
Default Re: (guymontag)
Yes, thank you that was my plan after work today. I'm gonna try to sit the injector in the rail first then the manifold. Just hoping I didn't pinched the o-rings, dam!
mw011i
Jul 18, 2008 05:06 AM
B18c1vicrx
Apr 8, 2008 06:21 PM
dabomb
Apr 17, 2003 02:22 PM
aemciv
Mar 24, 2003 10:54 PM
