DIY polyurethane engine mount?
ok i been doing some research and the only one i couldn't find how to do is the driver side mount for an si...any ideas/links?
http://www.superhonda.com/foru...04274
if yall need more help here another site
http://forums.evolutionm.net/s...66524
still doesn't help me with the driver side
Its the same, basically.
You'll have to remove the mount, drain it and fill it back up with the urethane. It would take a loooong time to dry completely.
(unless its busted...i advise against doing this - filling the two torque mounts will suffice)
I also suggest NOT gutting the mounts either - just fill around the rubber. You wouldnt want to place the sleeve in the wrong location and have **** not line up.....
Tie Ee Fei
64
Jan 17, 2019 04:45 PM
i-VTEC_do_you
Jul 29, 2010 04:12 AM
builthatch
Apr 19, 2007 06:20 PM
balistic CRX
Dec 27, 2001 04:37 AM
