sucking up gas.
Old Sep 6, 2007 | 10:19 PM
5thGeneration's Avatar
Default sucking up gas.
would a cracked cat. converter suck up my gas when i am driving? or would it be more in the combustion process?
Old Sep 6, 2007 | 10:42 PM
sol2hatch's Avatar
Default Re: sucking up gas. (5thGeneration)
need more info to help you out, are you getting bad gas mileage? When did it start, have you made any changes? etc.
Old Sep 6, 2007 | 10:49 PM
Default Re: sucking up gas. (sol2hatch)
just bought the car not to long ago. had a full tank drove 30 miles had half a tank left. i know for a fact the catalact converter has a crack in it. other then that i can not find problems.
Old Sep 6, 2007 | 10:52 PM
sol2hatch's Avatar
unless you have a hole in your gas tank, thats pretty much not possible. I would bet that your gas gauge is messed up. Either the actual gauge, or the plunger thing in the tank it self, or the wiring in between. Drive till your car runs out of gas, and that will tell you, just make sure to stay close to a gas station or your house, lol
your not smelling fuel, are you? is your car running fine?
Old Sep 6, 2007 | 10:57 PM
k ill try to igure it out. thanx
Old Sep 6, 2007 | 11:27 PM
903eg6's Avatar
something similar happend to a friend of mine and it turned out he about a pin size hole in a fuel line
pxlds
13
Feb 9, 2014 07:45 AM
dc4b20
13
Apr 16, 2010 07:01 PM
hannslebo
Jul 4, 2009 10:09 PM
E-Rok
Dec 26, 2003 12:55 PM
Tiwe
Sep 12, 2002 05:59 PM
